Question about Logitech K700 86-Key Wireless Multimedia Keyboard Controller w/Nano
K700 mouse button
Enter button
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
Tip
Toshiba SD-K700 DVD Manual Download
Download Toshiba SD-K700 DVD Player Manual
Have you misplaced your Toshiba SD-K700 DVD player Users Guide?
Would you like a digital, searchable, pdf version of the Toshiba SD-K700 DVD player Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
on May 03, 2010 | Toshiba SDK710 DVD Player
Tip
Toshiba SD-K700 Manual Download
I hope that helps.
on May 03, 2010 | Televison & Video
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
How to set network lock code on SE k700?
Network lock codes are available at www.mobileunlocksolutions.com along with the instructions of how to enter these codes and remove your network lock .
Oct 20, 2010 | Sony Ericsson K700
I need a master reset code as i have forgot my phone lock code and cant get into my phone
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jan 31, 2010 | Sony Ericsson K700
K700i codes
Well i know some of them too :)
>*<<*<* Is how you can access your service menu
>*<<*<*11 is how you can view what firmware your phone has
How to unlock your K700
To unlock your K700, you must first of all get the following codes from your operator; IMEI number, Code CCK, Code NCK, Code NSCK, Code SPCK and the Phone Code. Once these codes have been recieved, press <**< to view your phone's unlock status. Your phone should now display "Personalized with MNCx" (x could be 2 or 3, does not matter). Then press "yes" then you should go onto a "Personalize" menu with "network" highlighted. Now press yes, and the phone should display "enter NCK" or one of the other ones (CCK, NCK, NSCK, SPCK) Then enter that unlock code. Then press "yes" and if done properly, the phone should display "Network unlocked". If necessary, you may need to restart your phone to search for the network.
Please rate if helpfully!
Apr 07, 2009 | Sony Ericsson K700i Cellular Phone
Phone lock code
just enter wrong codes till it says enter puk code then for puk code call service provider & get it then try good luck
Oct 21, 2007 | Sony Ericsson K700
Logitech K700 86-Key Wireless Multimedia Keyboard Controller w/Nano Logo
14 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
