Whirlpool sm8525492 Cold water just dribbles in tub. Takes 30 minutes or longer to fill. No problem with water supply or plugged hoses. What could be wrong??????
MNTECH
  • 1543 Answers
SOURCE: Hot water in washer comes
Clean inlet screen where hose attaches to machine. Water from water heater is generally "cleaner" as sediments have had a chance to settle out in the water heater. Cold water carries more stuff directly to the valve screen. Check also for kinked hose.
Posted on Aug 28, 2008
SOURCE: Slow cold water fill in washing machine
Take out the screen on the cold water side of the fill valve where the hoses attach, its probably clogged.
Posted on Mar 17, 2009
SolutionGuy
  • 331 Answers
SOURCE: whirlpool washer model lsr8233eq1
Hi gastang,
The problem is with your water valve. It needs to be replaced.
To access the washer follow these steps...
UNPLUG THE WASHER!
1.) Remove the 2 screws from either side of the control panel.
2.) Pull the control toward you a 1/4", then rotate it up and all the way over.
3.) Remove the white plastic wire connector to the top panel (it has 3 wires in it.).
4.) Remove the two clips on either side of the top panel. Do this with a screwdriver. Poke the screwdriver into the top panel to engage the clip, now rotate the screwdriver toward the rear panel.
5.) Lift the lid (for a hand hold) and rotate the entire cabinet forward to about a 45 degree angle then slide it toward you. Set it aside.
Here's a video that shows how it's done. But you'll notice that the screws on your control panel are in the front, the video has the screws in the back, but the rest is the same. Here's the video.
After you have access, you'll see the water valve on the right.
If this was helpful, would you take a moment and rate my solution? Thanks,
SG
Posted on Mar 29, 2009
canbruce75
  • 1776 Answers
SOURCE: Washer takes about an hour to fill halfway with water
Check the solenoids on the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Aug 09, 2009
woodchuck789
  • 4059 Answers
SOURCE: water fills very slowly
Did you check the screen filter in the end of the hoses on the washer and the end that screws to the water supply.
Posted on Oct 14, 2009
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
My Whirlpool Cabrio washer model WTW5610XW0 type 588-02 spins then stops and clothes still come out wet.
The washer is unbalanced, make sure it is level and the clothes are distributed even, if this have been check. put the unit on cold water and see how fast it comes in. Safety programmed into the unit if it takes longer then 10 minutes to fill it will just drain. This is to keep the washer from flooding out. Check the water inlet where the hose screws on, it could be plugged up with grit
Dec 12, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
On brand new machine the water pressure is ok (not great as we on low pressure) to back of machine but just dribbling out into tub... Model F&P MW612WH 6.5kg
hi - these machines wioll require sufficient pressure to operate - but low pressure to a certain degree should be fine - takes longer to fill..
Suggest you double check the hoses to the right valve hot/cold etc - usually there is a filter on the hose and one on the inlet valve, hopefully its not blocked.
I cannot see any other component that would be faulty - as you say its brand new...
Jun 24, 2011 | Fisher Paykel EcoSmart GWL15
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
Hi the cold water just dribbles into the tub. if I
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Washing Machines
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
May 20, 2010 | Washing Machines
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Nov 21, 2007 | Washing Machines
Wash cycles are increasing in time required to complete
cold water valve in back could be plugged causing longer fill times.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
IS THIS HAPPENING ON COLD AND HOT WATER RINSE ??? THERE IS AN ELECTRIC SOLENOID VALVE FOR HOT AND COLD WATER SUPPLY. THESE SOLENOIDS HAVE STRAINERS AND ORFICES THAT CAN CLOG UP WITH SEDIMENT IN THE WATER SUPPLY ... MOST ALL OF THEM ARE CLEANABLE. THIS IS NOT AN EXPENSIVE REPAIR ... BEWARE!!!
Apr 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
