Question about Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount
Holmes fan making noise
Making noise
I need a 3-speed fan switch for a Holmes stand fan #HASF1522
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
Jan 31, 2015 | Holmes Products Dryers
HI,,our asimo stand fan FL-16RD with remote control,is not working and making some noise if we turn it on
Pls help locate ASIMO electric fan service center in Manila. I need control board parts.
Thanks and brgds.
Apr 11, 2013 | Holmes Products Dryers
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
I had a holmes HPF 650 MCU outdoor pedestal fan which worked great for five years and then abruptly stopped working. Rather than repair it, I tossed it out thinking I could purchase another one. ...
Hi Bill.
Holmes makes a very good fan.
You can buy a new one here:
http://www.overstock.com/Home-Garden/Holmes-HPF650-U-Oscillating-3-speed-Stand-Fan/3473589/product.html
Good luck from Detroit, MI.
Sep 18, 2011 | Holmes Products (HPF650MCU) Stand...
I have a 16" black
Contact Holmes at: http://www.holmesproducts.com/warranty.aspx
This is a do-it-yourself help site that is in no way part of Holmes products.
John
Aug 31, 2011 | Holmes Products Dryers
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
Hi, my fan just started making some noice and when i opened to see what was going on after fixing it the fan will not strat again
Please check all cables connections for loose in fan. The noise may coming out from wear down bearing.
Regards, Jay
Feb 21, 2011 | Holmes Products Ace Trading-holmes (2)...
We have two holmes fans and they both stopped working within the same week, we replaced the batteries and nothing and we tried to manually start them and nothing; any ideas>
mcdevito75 here, You say you changed the batteries in both fans, tried to spin the blades and no start., Double check battery install, try another set of batteries even new batteries from the store can be weak or even dead as batteries have shelf life of, not too long. Spin the fan blades as fast but as safe as possible by hand with the on /off switch off, and listen for any noise from the fan motor, a sraping sound, or whistle could mean a bad motor. Lastly, bring the fans to a Staples, they will be glad to test them, a Radio Shack also can test the fan motors.
Jul 28, 2010 | Holmes Products HAPF622R Floor / Box Fan
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount Logo
57 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
ray gallant
xkikbxr
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
