Question about Canon SELPHY ES1 Thermal Printer
Selphy ES1 printer switches on,
My Selphy ES1 printer switches on, the "Canon" screen is displayed but no response to any button pressed. Print/Paper cartridge checked and replaced. Cannot send jobs to print, nor read SD card from camera. Prior to this the printer was working well.
    Sergeant:
  • 321 Answers
Remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Posted on Jun 18, 2009
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: http://canoncanada.custhelp.com/app/answers/detail/a_id/10212/~/error-messages-displayed-on-the-screen-(selphy-es30) For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
My pixma ip8500 is printing with some colour missing, all cartridges have ink in them?
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
The pattern print confirmation screen is displayed.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 01, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
When i try to print on my Canon SELPHY ES1 i get a message saying "Cartridge has changed" and it won't print. Can you help?
Check "Printer Properties" so that the cartridge is set to color if E-Pxx cardridge is mounted and set to B/W if E-PxxBW cardridge is mounted...(xx stands for number of postcards) // Kjell.sundling@hotmail.com
Aug 30, 2008 | Office Equipment & Supplies
I am printing on a Canon Selphy ES1. The media package - ink and paper combined - it has just been replaced with a new pack and I get the following error message on my Mac: "Failed to receive data...
Jul 14, 2008 | Office Equipment & Supplies
Canon SELPHY ES1 Thermal Printer Logo
240 people viewed this question
old marine
old marine
