Question about Ovens
My Bosch oven model HGS435UC/01 won't heat up
2 Suggested Answers
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Bosch oven HBN 1312.0
    Please double check the model number on the unit. On the Bosch site, I found a number of models with that started HBN1312* . However the model number had another digit after the 2 and the zero was followed by a letter and a slash before additional numbers.
    The model HBN131220B/01 is an all electric oven. The external dimensions for the wall oven are 595mmx595mmx515mm. I'm not sure about the internal capacity for the unit. Some documentation (including the user's manual) are available from the Bosch support site: http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM . Enter HBN1312 in the search box to find the documents.
    I hope this helps.
    Nov 24, 2013 | Ovens
    Tip
    Bosch HBN13M250B/01 not heating or fan is not turning, common faults.
    For all Free Bosch appliance repair videos visit our VIDEOTUTORIALS
    A fan oven that has stopped heating up is probably the mostcommon oven fault that professional engineer is called to. The cause inmost cases is simply a faulty fan oven element. To employ the services of arepair company is going to cost you in the region of £60 - £100 to complete thejob.
    With a little time, though and our FREE fan oven element video itshould take less than half an hour to repair, and the element can be purchasedfrom us for as little as £20 ! Why not Save yourself some money and read on
    1, If the Bosch fan motor in the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter.
    To gain access to the Bosch element you will haveto remove the back plate from inside the oven. Once removed you will see the Boschfan and element, if you look closely at theBosch element you will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but the element is open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
    2, If your Bosch fan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your oven fan motor is workingyou will see the blade turning fast if it is ok. if the element is heating butthe fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
    3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace your Bosch oven thermostat
    4, A quite common and easily overlooked answer isif your oven is not working atall ie: no heat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
    on Jan 13, 2010 | Bosch HBL 5052 Electric Double Oven
    Need instruction manual for Bosch Oven HBN43M550A
    Bosch has the manuals for their appliances on their support site: http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM . If needed, click on the Service and then the Use Instructions links. Do you have the HBN43M550A/01 or the HBN43M550A/03 oven? The direct link to the manual is http://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qkFj3rbcdcso0pdmdb---YUw&UMOBID=qkFj3recdcso0pdmdb---YUw . I am not sure if this link will work; if it doesn't, start at the earlier link and enter your model number.
    I hope this helps.
    Sep 30, 2011 | Ovens
    Is it possible to turn my Bosch oven in to 110 volt? Model number HBN58T650A Thanks
    I did a search for this Bosch oven-
    It sounds like the oven is not a conventional Resistance heating oven-
    So it might be possible--
    Do you have the manual for it?
    I tried this web site: visit the website: www.bsh-group.com.
    But It was not much help
    Perhaps you can look in the phone book, and contact your local BOSCH appliance dealer, and have them look up the model in their Model catalogs?
    Or-- You could pull the oven out, and check the wiring harness--
    No doubt it will tell where the main cord comes in, -- if there is a hook up diagram for both 110 Volt,and 220 VAC connection diagrams-
    When you get it out, tell us what you find-- maybe we can help further..
    MackB
    Jan 29, 2011 | Ovens
    Bosch range outter glass shattered
    You just need the glass, get part number from Bosch website (UK) and source locally.
    To fit just dismantle the door.
    Aug 29, 2009 | Ovens
    Hello could you tell me were i can get the glass front door from for a neff b142wogb/01
    yes you need to go online to bosch website and look for quickfinder this is the tool used to locate spares, the site is for bosch neff seimens as they are all one company put in your enr number or model number and you will get an exploded diagram of your oven you can then find part number.
    I looked and it appears to be 297595 in brown or 297601 in white retails at £61.03 ex vat
    HOPE THIS HELPS.
    May 09, 2009 | Neff B1421 Electric Single Oven
    Replacing interior oven light
    Here is the manual for your unit:
    Bosch HBN3550/01
    The instructions are on page 31.
    Hope this helps and please remember to rate this!
    Dec 06, 2008 | Bosch HBN 3550 Electric Single Oven
    Bosch hbn s gb
    oven element would need model and ENR No. to supply
    Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
