Question about General Filters 1042-LH Humidifier
Water runs out of bottomof humidifier - General Filters 1042-LH Humidifier
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
I think my humidifier does not work. I switch the control button to outside temperature rating and inside the house the humidity level is 11%, which is to low. What should I check? How do you know that...
On the water line running to the Humidifier there should be a On/Off valve. It may be a saddle type valve. In any event, this is how you can tell if the water to the humidifier is turned ON. Look for either plastic or copper tubing running from a water source to the humidifier.
Feb 23, 2011 | Carrier LBP Humidifier
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
Water runs without furnace running
If this is a new problem, on an existing humidifier, then it is most likely a bad solonoid valve. This is the valve that the water line is connected to, and it controls the flow of water to your humidifier.
If this is a problem on a newly installed humidifier, it is possible to have wired the humidifier directly to the transformer power, and therefore holding the valve open all the time.
Hope this helps
Nov 03, 2010 | Aprilaire 700 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
Water running after heater shut off in humidifier
Hi check power at transformer / valve on water line could be stuck open clean valve out or transformer holding valve open
Dec 31, 2009 | Aprilaire 558 Humidifier
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Water not running through humidifier
Sounds as if you feel the problem is the saddle valve. Check to see if water is available at the humidifier. Close the saddle valve, disconnect the water line at the humidifier side, then slowly turn the saddle valve back on. If you never see water, then correct the saddle valve. You can get details here: http://www.naturalhandyman.com/iip/infxtra/infsad.html#1
If you are getting water, but dont think that the unit is operating try sending 24VAC directly to the hunidifier and see if it operates, bypass the humidistat etc.
Dec 08, 2007 | Honeywell HE220A1019 Whole House...
General Filters 1042-LH Humidifier Logo
Top General Filters Humidifiers Experts
Mack Baxter
Dennis
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
