Question about HP VP6310 Multimedia Projector
How to repair hp vp6311 color wheel sensor - HP VP6310 Multimedia Projector
Hp md6580n, if the color wheel is bad, how do I change?
Go here, download & read Color Wheel section then go back to HP site to order part, Good Luck!
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&product=472490
Nov 13, 2013 | HP Televison & Video
Projector
The sound came from the switching power supply and the lamp ballast circuitary. You need to replace the color wheel sensor, I can fix it.
Jan 18, 2009 | HP VP6310 Multimedia Projector
Projectors
The color wheel sensor is bad.
HP vp6320 projector
You need to replace the color wheel sensor. I can fix it.
Dec 01, 2008 | HP vp6320 Multimedia Projector
Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hp vp6310
If you have no indicating LED, then main power supply is dead. If you have indicating LED but lamp don;t turn on, then it is either the ballast or color wheel sensor.
Aug 23, 2008 | HP VP6310 Multimedia Projector
Color problem after warm up.
The probelm is caused by either a bad color wheel sensor, color wheel or formatter board. I have the new redesigned sensor assembly and color wheels that I can sell. It is best if you send me the projector for proper diagnosis.
Apr 30, 2008 | HP vp6320 Multimedia Projector
Hp vp6320
For sure this is caused by failed color wheel sensor. HP redesigned this assembly twice and the last design change worked very wheel. The new sensor assembly comes with new temperature sensor cable, focusing spacer. I am factory trained and I can repair the projector for you.
Apr 11, 2008 | HP vp6320 Multimedia Projector
Hp projector
This is caused by the color wheel sensor failure. The sensor is mounted very near the lamp and suffered extreme temperature. This problem can be corrected by installing the redesigned color wheel sensor. You also need to refocus the sensor due to different focal length. HP also recommended to replace the temp sensor cable. If you still have the projector, I can fix the problem for you.
Jan 08, 2008 | HP vp6320 Multimedia Projector
HP VP6310 Multimedia Projector Logo
75 people viewed this question
Seeker5211
Seeker5211
