Question about Briggs & Stratton Garden
String wont pull its stuck - Briggs & Stratton Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Blower string wont retract
you might have installed the wrong spring type, check also the stopper or the lock inside that holds the spring secure.
Jun 04, 2013 | Garden
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
My pull string wont move on my ryobi x430
Mine seized up and the string wouldn't pull because my girlfriend used it a few times without making sure that the oil was full. I filled the oil well with Marvel Mystery Oil and was able to slowly get the string to move. Eventually the motor became lubricated enough to pull the string with regularity and now the weedeater works perfectly.
Apr 06, 2012 | Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
HI I BOUGHT A 1969 TALKING SERVICE STATION BUT THE PULL STRING IS JAMMED PULLED OUT HOW DO I FIX THIS AND GET IT TO TSLK AGAIN
mcdevito75 here, you may not be able to as the spring on the pull string may have lost it"s tension or the pull string mechanism is just stuck. You may not even be able to get at the mechanism if it"s a sealed unit, if you can get at the mechanism a little penetrating oil may help. Contact the toy manufacturer online or phone for more help.
Jun 26, 2010 | Toys
32cc crafstman weedwhacker (2 yrs old)flooding wont start
Nope, it's not the carb. The plug is wet and probably black as well. Wet plug and lots of smoke means too much oil in the mix which is where the problem lies. Get a compression tester and look at the pressure reading; anything less than 90psi means the piston ring is stuck and needs to be replaced/cleaned.
Oct 07, 2009 | Garden
The string in the spool of the weed eater is stuck. How can I remove the string and how can I avoid this problem in the future? I'm using the pre-cut strings. Thanks
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
Sep 20, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
11 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
