Wany power outrput info pn a traynor 4200 mixer amplifier 4010406
How do i set up a Peavey xr560 mixer and graphic equalizer
PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
Oct 12, 2014 | Peavey Audio Players & Recorders
Need manual and part number for brushes on a Kitchenaid RRK90
If it looks like the photo beside the blue panel above I'd say it's a KSM 90 so you should be able to find your motor brushes and a downloadable manual with the help of Google. If you are in NZ I have brushes and can copy the manual for you.
Aug 31, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Hooking up other external systems
Peavey XR 1212 You may find helpful info from the Peavey site. I'm not sure how you want to configure your setup, but the tape out may be able to feed the power amp.
Mar 24, 2014 | Peavey XR1212 12 Channel Powered Mixer
Where are the Amplifier inputs on a Behringer usb 2222 mixer
If you need a better answer post again with more details. You can connect an amplifier to any of the inputs assuming it has compatible output levels. In your case I am assuming you want to connect to a power amplifier, so connect to the Main Outputs.
This mixer does not drive speakers!
Nov 10, 2012 | Behringer Xenyx 2222FX 22 Input Mixer
Setting up pv20 usb
http://www.peavey.com/products/index.cfm/item/699/116338/PV%26nbsp%3B20%26nbsp%3BUSB
Look under "Downloads" tab at bottom for owners manual info. In a nutshell...mic to mixer channel #1, mixer connected to power amplifier, amplifier connected to speakers. Start with zero volumes on all equipment, bring up amps 1st (1/2 volume) and then adjust mixer until sound is heard from the microphone.
Oct 31, 2012 | Peavey Music
We have a Dito Dean Food Prep EM30 Mixer that we use at a camp for children! We are a non-profit group! Our mixer flat beater part # 30 273 has broken. We tried to find one at a restaurant supply but were...
Here's the contact info for the company that made that mixer.
The Electrolux Professional Inc. headquarter
are located in Charlotte, NC at:
10200 David Taylor Drive
Charlotte, NC 28262
Phone: 866-449-4200
Fax: 704-547-7401
I hope this helps you.
Bobya.
Jul 01, 2011 | Dito Dean Food Prep EM-30 Stand Mixer
Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Aug 10, 2009 | Audio Players & Recorders
Speedstream 4200 gaming issues
dude i have the same problem but the only wany u can fix that is getting a new one because your NAT is set to Struct and to play some of the games like Halo 3, Saints Row 2, and other 360 games you need to have it set to open.....
May 12, 2009 | Siemens SpeedStream 4200 (13A4200001)...
SETTING LEVELS ON MY POWER MIXER FOR MICING DRUM SET
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
May 12, 2008 | Samson SX1200 Amplifier
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
