Question about Ovens
Kenmore 316218628 oven does not work
How do you light the pilot on a Kenmore gas oven?
we have a kenmore stove in kitchen and it has a ignitor that glows for oven. if the oven will not work check out the ignitor for oven. just remove bottom cover of oven, then you will see it. this is for electric ignitors.
Feb 10, 2012 | Kenmore Ovens
Kenmore gas oven will not light.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 26, 2011 | Kenmore Ovens
How can i ligh pilot on of kenmore oven
heatman101
Jun 29, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore gas oven model 36275578690 oven wont light
heatman101
Apr 20, 2011 | Kenmore Ovens
Kenmore Oven does not get hot
heatman101
Jan 05, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
How to relight a kenmore oven it wont relight
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 13, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My kenmore oven's led display works, but will not heat
pull stove out and check the volts either on the plug or terminal block on the stove where the wires are terminated. check the terminals marked L or line at the same time should have 240 volts if not your breaker which probably is a 40amp will need replacing
Sep 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 75358 -oven not lighting
heatman101
Feb 26, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
