SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time.
These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
SOURCE: I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
SOURCE: Sunbeam Ultrasonic Humidifier SUL495 quit working
Same problem. It worked for about a week, then gradually stopped producing mist. No solution.
