Question about Tomtom ONE GPS Receiver
Tomtom won't turn on - Tomtom ONE GPS Receiver
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
Tomtom one won't go past voice person. It keeps starting over.
You have installed a NavTones GPS voice that is encrypted to a different device code (serial number).
  1. connect TomTom to PC
  2. navigate to 'voices' folder
  3. Delete any recently installed voices
  4. Disconnect and restart
Aug 04, 2011 | Tomtom ONE GPS Receiver
I don't have password for my tomtom one. i have got a second hand tomtom and it won't let me get past the page with the numbers asking for password. I have pressed the reset button, but it...
If you purchased a used TomTom from someone, you would have to contact that person for the password, or have an affidavit of ownership and have tomtom reformat the drive.
Jul 11, 2011 | Tomtom GPS
I set up my Tomtom and it gives accurate directions, however it won't talk to me. According to the volume control, it is at 100%.
Have you checked in the settings, there is a setting for turn sound off, this overides the volume.
It is under change preferences from main menu, and is a red square with a speaker on it
May 10, 2011 | Tomtom XL 340TM 43 XL340TM
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
How do I reset my TOMTOM N14644?
Go to TOM TOM´s homepage http://www.tomtom.com/services/
Connect the GPS unit to the PC using the USB2 connection.
You will be given the possibility to restore the unit´s files. This takes a while, but it solved the problem for me.
Nov 04, 2009 | Tomtom ONE GPS Receiver
GO 510 WON'T COME ON . CONNECTED TO COMPUTER STILL WON'T COME ON
Have you tried?...
My TomTom device won’t turn on. How can I reset my device? = www.tomtom.com/7134
Jan 10, 2009 | Tomtom GO 510 GPS Receiver
Tomtom won't turn on or off. So I can different screens
does the socket in your car stay powered on even when the car is turned off most likely not and you just need to charge your device will itcome on when it is in the cradle for the computer
Dec 27, 2008 | Tomtom ONE GPS Receiver
TomTom 910 won`t turn on
try charging both in the car and on the home charger
try a doft reset
www.tomtom.com.7134
Jun 22, 2008 | Tomtom GO 510 GPS Receiver
Tomtom ONE GPS Receiver Logo
18 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
