Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Com mode how do you select a com mode on a bizhub 350
  • Konica Minolta Master
  • 6,161 Answers
Do you mean fax mode?????
Posted on Jan 10, 2016
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
Jul 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to reset to admin code on bizhub
1. Press the Utility/Counter key.
2. Touch [Check Detail].
3. Press the following keys in this order.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
Then
1. Call the Tech. Rep. Mode to the screen.
2. Touch the [Administrator # Initialize].
3. Select [Yes] and touch [Enter]. defaults the PW 12345678
Feb 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning to e-mail - Bizhub 215
This setting is only for bizhub 200 - 350
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
Aug 01, 2012 | Konica Minolta Office Equipment & Supplies
Connection using ip address for bizhub 350 from desktop
If you want to check the connection from desktop ten follow this.Click on start menu.In run, type cmd and press ENTER.Now in dos mode type ping>space>ip address of machine which you want to check. press enter.If it shows TTL=32 or ttl=64 then it means OK.Your machine is connected with desktop.
Now if you want to put your machine on network and want to assign IP to machine then do these steps1-Connect the network cable to machine.2-Assign an IP to machine.3-To assign the IP, Simply press "Utility/counter" button.4-press "check details" button on LCD panel.5-Now press Admin management.6-Enter password. 123456787-select ADMIN 28-select Network settings.9-Select DHCP.set it to manual instead of auto obtain.10-Now assign the IP in IP address option and after entering correct free ip restart the machine.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
Getting c2557 code how do I fix? on bizhub 350
Welcome to Fixya
Sounds like you nee to replace the developer. Try to reset the printer first. Enter the service menu by pressing utility > original size> stop>0>0>stop>0>1 the password is 00000000, in the service menu select tech mode, go to counter and clear the life of the developer and drums and then run F8 from functions.
Thank you for using Fixya!
Jul 02, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Please we need an operators manual
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
in the box Category select" office systems" the in the next box Model select "Bizhub 350" in the last box Manual Type select "User Guides"
This will show all of the guides for that model. All of the guides can be downloaded as PDFs.
May 10, 2010 | Minolta bizhub 350 Black and White Copier
How to enter sevice mode on the Konica BizHub 350?
Administrator pw is "000000000"
Service pw is Utillity + counter + "stop" 0 0 "stop" 0 1
stop 9 mode 1
Mar 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
