Question about Ariens Garden
Axle seal Ariens model 935335 hydro tractor leaking what appears to be grease or oil around seal at rear axle where it comes out of transaxle into tire also how do I check fluid in transaxle
  • 708 Answers
There is a plug about halfway up in the transaxle, fill till lube runs out. You will need a new seal in the unit eventually, but if leakage is not real bad you can just add the oil recommended by the manufacturer. Hope this helps, plese post solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on Apr 24, 2014
SOURCE: I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Posted on Apr 20, 2009
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
  • 57 Answers
SOURCE: Can I add fluid to rear tires w/o hurting rear end.
Adding fluid to the tires should not affect the transmission at all.
Posted on May 19, 2009
  • 130 Answers
SOURCE: Hi Guys, Have a Murray ride-on with both rear axle
you can fine this information on the internet under murray riding mower.com in most cast
use 90 w oil in the gear boxs
Posted on Jul 18, 2009
  • 3 Answers
SOURCE: Transaxle appears not to engage
rider will not go forward or back
Posted on May 18, 2010
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
There appears to be some kind of breather tube (?) going back into the top of the transaxle of my kubota g1800 tractor and is blowing hyd fluid out around where it attaches. what might be my problem?
if it is a breather tube and pressure is building up , it is possible that there is oil in the tube and combined with dust it has gone solid and is blocking the breathe
check for any low areas of the hose that might retain oil
Jun 30, 2016 | Kubota Garden
Ariens model 935335 hydro tractor leaking what appears to be grease or oil out of seal around the axle where it comes out of the transaxle also how to check fluid in the transaxle
look for a dip stick it may be color coded with a yellow end or their may be a tag directing you to were it is located the seal may be bad
Apr 14, 2014 | Ariens Garden
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Leaking rear axle seal
If has a Peerless transaxle you need a oil seal 780088A. Its where axle comes out housing. Just pry it out and replaced.
Aug 05, 2013 | Craftsman Garden
Clutch control husqvarna
It is not good to drive the machine with either unit in bypass, the worst that can happen is it will buikd up case pressure and lift the bypass shaft in the hydro, this will then spary oil everywhere, if you are lucky you can just push the shaft back down, there are rubber seals on the lower part of the shaft that should re seal, if there is no sign of any oil spill there is no problem.
Jul 03, 2013 | Garden
Where to put rear end oil at?
On what? If your transaxle is a sealed, owner's manual
should tell you. A seal unit, you may have to take top
half of axle housing. Or drill a small hole and then it.
Jul 28, 2012 | Garden
Engine oil leeks between gearbox & engine
Sounds like a rear main seal, the crankshaft's rear main engine seal. On newer vehicles, it is a one-piece design, and easy to install. The problem is the engine and transaxle have to be separated to get to it. You would either have to pull the engine and transaxle out of the car together for separation, or drop the transaxle and replace the seal with the engine still in the car.
Of course you'd want to know for sure it was a rear main before you started. Check the oil pan carefully around the rear of engine for leaking there. If you clean the area around the leak, you may spot where the new oil comes out. Parts stores have kits for sale to detect leaks. You put a dye in the oil, and use the flourescent light to spot the oil leaking with the flourescent-sensitive dye in it. I hope you find it, good luck.
Apr 07, 2012 | Cars & Trucks
2008 Husqvarna YTH 2348 is loosing power...
it has a leak from the head gasket,ive done many with the same problem.pop the head off and change the gasket,also check the rings ect while apart
Dec 30, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
379 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
