Question about Garden
How do you change out the front main motor oil seal on a 430 diesel John deere
Instructions on How to change out front main motor oil seal
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a john deere 430 garden tractor diesel.
Sounds like the fuel pump stoped working.
Posted on Aug 26, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
How to find and repair oil leaks in front of motor?
Ok ralph first off clean motor with engine brite found at any auto parts stores
next recommendation add oil base dye to motor oil allow to run for 30 min to circulate dye useing a uv lamp or black light and inspect front cover most cases the front seal is themost likely source of leaks due to contant revolutions on front main seal
in order to repar suspected seal total dissasembly of timing cover will have to be removed in some models the front main bearing journal will have to be removed as well.
upon removal of timing coverbinspect front mail seal race / face for burnishing of the crank seal face. Dirt an debri cut into the crank
you will have to order the front seal repair kit
consists of front seal and stainless steel wear ring wich is glued in with epoxcy
reassemble front timing cover gaskets an sealer may be needed once all the parts are reassembled run for 15 m7n an check for leaks
its also possible that the oil pan gasket could be leaking as well
install dye to find leak is the best course of action first
Jun 22, 2014 | 2003 Chevrolet Impala
Oil leak front engine timing chan
1995 Tracker would have a timing BELT. Normal oil leak points (in order) on a Suzuki G16 engine are the distributor base (rear of motor), valve cover (top of motor), front main seal (behind lower timing belt cog) cam seal (behind the upper timing belt cog) and rear main seal. (behind the flywheel). I'd suspect the front main seal or cam seal. I use foot power to help find oil leaks.
Dec 24, 2012 | 1995 Geo Tracker
How hard is it change front and rear oil seals?
By front and rear oil seals, I am assuming that you are refering to the CRANKSHAFT front and rear oil seals.
The front crankshaft oil seal is under all the components that must be removed to replace the timing belt.
The standard labor time to replace this seal is 4.0 hours for the 4 cylinder and 4.8 hours for the V-6.
The rear crankshaft oil seal requires removal of the transaxle to replace it.
The standard labor time required to do this is 7.3 hours
This is not a job for a novice unless you want to purchace a service manual and spend a lot of time reading the instructions before jumping into it.
Dec 01, 2010 | 1995 Honda Accord
2000 go tracker bad oil leal back of motor have changed rear main oil seal front trans seal oil pan gasket still leaking even changed crank sensor oil ring &sensor .
It has to be an oil pressure sending unit. There are two of them on that SUV but they are in different places depending on your engine cord. If you go to Advance Auto parts or O'Riley, they will tell you exactly where to look.
Nov 18, 2010 | 2000 Chevrolet Tracker
Change front main seal , leaking oil around timing chain cover. could be seal around harmonica balancer.
yes, I just changed one of these recently. Had to take both front and bottom off engine. Very difficult repair, as there are no good jack points for the engine when you have all the motor mounts off.
Here is procedure I would recommend.
Remove starter and engine to transmission brackets front and back.
Remove transmission starter gear cover.
drain oil and remove oil pan.
put a block under the crankshaft and jack to release weight on motor mount.
remove front motor mount (by serpentine belt)
remove belt.
remove compressor and bracket.
remove crank pulley and vib damper.
remove timing cover. mark timing belt with direction of travel
loosen tensioner gear.
remove timing belt.
remove crankshaft timing gear and key.
remove seal and oil pump housing.
clean gasket surfaces.
replace seal and reverse procedure.
If you have questions, let me know.
Oct 06, 2010 | 1993 Dodge Caravan
Leaking oil fro the bottom front I had the motor changed and they say its the main seal . But i want to do it myself
Its likley the Crank seal, also called front main ( rear main being the end that meets the transmission.
Its pretty easy to do you just have to remove the serpentine belt, and remove the crank pulley, then you can pry out the old seal with a pick or screwdriver, clean the area from dirt and debris. then put the new seal in place, you can use a large socket that fits the ring of the seal, and hit it in with a hammer, keep hitting evenly around the seal so it goes in straight
Apr 10, 2010 | 1994 GMC Sierra
Oil leak
that motor known as a leak motor f22,check this front cam seal,cranks seal,balancer seal,rear main seal and distributor seal those are the main common problem
Dec 16, 2009 | 1995 Honda Odyssey
How to change front main oil seal on 2001 chevy 8.1
you will need a puller to remove the front crank pulley/ balancer. then its a matter of prying the seal out.
Oct 19, 2009 | 2001 Chevrolet Silverado 2500HD
Main seal
First is it a front seal ,or rear main seal,(front seal,being were you see the pulleys and fan belts,,you have to look at the bottom pulley,follow the shaft to the motor,where the shaft goes into the motor is the front seal,the pulley and everthing behind it has to come out then you pull out the seal,auto zone actually has free tool rental that you can pull the seal,and a tool to put it back in,if a rear main seal its where the shaft from the transmission meets the back of the motor,youll have to pull the trannsmission back,check where you see the oil leek from,the front seal you can do if mechanically inclined,but if its the rear you should take to a mechanic,if this helps please give me a fix ya vote
Jul 14, 2008 | 1997 Chevrolet Malibu
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
