Question about Brother HL-2070N Laser Printer
How to set an IP address on a HL-2070N printer?
Our HL-2070N got an IP address set up and it worked fine before we sent it to a printer shop for a hardware service. The printer shop said they didn't touch the network card. But now the printer couldn't be detected on the same LAN. When I chose the old network printer name with the old port, it showed the printer is "not-connected". It looks like the IP set up has been lost. How do you set up the IP address on the printer again? (Unfortunately the person who set up the IP address before was gone and there is no any manual left).
    President:
  • 828 Answers
Reads the manuals and download it.
Posted on Jun 18, 2009
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
Trying to set up my IP Address on HL-217OW
Sometimes, you have to install the software, then install the hardware. Try plugging it in to a different port on the router. Make sure the plug is seated properly. try a different cable. Read the install documents that should be with what you downloaded, or online where you got it from. Read the FAQ's at that site. Okay, here is a real funny one, try Windows troubleshooting.
Sep 11, 2009 | Brother HL-2070N Laser Printer
Printer knocks, won't print
Try to reinstall the software and should be fine.
May 15, 2009 | Brother HL-2070N Printer
When installing Brother Network Printer undetectable
You have to know the IP Address of your printer before using it on the network. Once it is connected to a LAN, go through the printer menu - network setting - IP and print it out. With this you can publish the address when prompted ok. Or simply attach it to a pc and share it over the network. However, the pcs must be in the same workgroup or domain so as to see themselves. Good luck
Apr 28, 2009 | Brother HL-2070N Laser Printer
Ip address for brother 2040
Up to 20 pages per minute
• HQ1200 resolution (up to 2400x600dpi)
• HL-2040: 8MB memory standard
HL-2070N: 16MB memory standard
• 250-sheet input capacity
• USB 2.0 and Parallel interfaces1
• Built-in Ethernet Network Interface1 (HL-2070N)
The 2070 has networking not the 2040, according to the borchure, you would not be able to network this one, only usb and parrallel port. You could do it if you wanted to use a computer as your network printer server. In that case just use your router to select an ip address for that machine and either run it in DMZ if you have a linksys . If you just enable shared printer it should work on all your machines on the network. That's how I did it prior to a 4in1 wireless.
http://www.brother-usa.com/VirData/Content/Printers/ModelBrochures/Brochures_HL2040.pdf
Mar 19, 2009 | Office Equipment & Supplies
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
Printing blank pages
This sounds like a laser or high voltage problem. Very much technical to fix.
Nov 01, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N won't feed paper from tray
I had the same problem with 2 of the 2070N printers. Solution was that the paper tray was setting to tight against the paper pushing it tight up to the front of the tray. Back the rear support up so there is maybe 1/16 inch clearance between the paper and the end of the tray. No more feed problems.
Jun 04, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N
make sure the protocall is enabled for your specific printing preferences.
if not sounds more a computer issue.
May 16, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
1,428 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
