Question about Magic Chef CDB1500AW 24 in Builtin Dishwasher
Magic chef door won't open - Magic Chef CDB1500AW 24 in Builtin Dishwasher
  • 10 Answers
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Posted on Feb 20, 2009
snakehead
  • 1074 Answers
SOURCE: blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
Posted on Mar 01, 2010
meztang
  • 112 Answers
SOURCE: i have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
  • 7 Answers
SOURCE: MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Posted on Jan 29, 2011
My magic chef microwave turns on when I shut the door and turns off when I open it
Check for a defective door switch (usually secondary switch) to see if it is functional.
Nov 23, 2016 | Magic Chef Microwave Ovens
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
My magic chef dishwasher door springs broke. I need to know how to access the bottom of the dishwasher to replace the broken parts.
Open the back door and see whether the hooking points visible.
Look from the front end also to get an idea!
May 21, 2010 | Dishwashers
My Magic Chef Microwave is unresponsive and the display says "loc"
My magic chef is not working But when we open the door light is flash
Aug 12, 2009 | Magic Chef Microwave Ovens
Magic Chef Refrigerator door flys open
Sounds like you have the unit out of level front to back leaning towards the back. Try leveling or just tilted a little with the top leaning just a little toward you. This should keep it from flying all the way around.
Jan 05, 2009 | Magic Chef CTB1922 Top Freezer...
Magic Chef CDB1500AW 24 in Builtin Dishwasher Logo
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
