Question about Desmond 20.5 cu. ft. / 580 liter Upright Freezer Gold Line GB7-2UL
I need a manual for Desmond Gold Line GB7 Upright Freezer
Frigidaire upright freezer is leaking water from the door What is the problem?
Hello friend, I appreciate your post!
From the information you have provided your Frigidaire freezer is leaking water from the door. It could be a build-up of condensation on the interior of your freezer or the drain line. I would recommend checking the gasket to make sure that there is no visible damage you should also check the gasket to make sure it is sealing properly. You can use a dollar bill to check the gasket. Place it between the freezer and door, if it comes out with little resistance then the gasket is bad.
You can also perform a manual defrost on the freezer by disconnecting power from it for at least four to six hours. I hope this is helpful information. -Matt
Mar 16, 2015 | Frigidaire Upright Freezer
Need a user manual for a thermatech kbf2340 upright freezer
I would like manual for theramatech temperate upright freezer controls are on the front on the right hand side has pro & mute on one button arrow up with aux
other button has set def with arrow
Feb 14, 2014 | Freezers
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
Hai this is arun from oman.. i want to know how to
Check the defrost timer is operating and that the defrost heat element is working, usual cause of ice build up in most units, you may want to get an electrician to do it coz one wrong move it WILL kill you. Good luck.
Dec 18, 2010 | Desmond 49 cu. ft. / 1388 liter Commercial...
How do I adjust the freezer temperature on a Kenmore upright freezer?? Brand new, model number 461.27432, didn't come with a manual.. can't tell whether 7 or 1 is considered the coldest temperature?
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Kenmore Freezers
Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Mar 11, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have a Kenmore Upright Freezer. I need to
I unplug mine and let it take several days. You break a line or punch a hole in a line and the freezer will be ruined. Just let it thaw out on its own to prevent damage.
Feb 10, 2010 | Freezers
Upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Jun 30, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Desmond 20.5 cu. ft. / 580 liter Upright Freezer Gold Line GB7-2UL Logo
126 people viewed this question
Top Desmond Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Desmond Freezer Expert? Answer questions, earn points and help others
