Question about Garden
Have to pull 1987 atm 600 gator to start - Garden
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
Jul 27, 2016 | John Deere 2010 Gator XUV 4x4 620i
Where to fill oil on a 1987 cbr 600
Crankcase side. Two point three quarts to start then top off.
Oct 02, 2012 | 1987 Honda CBR 600 F Hurricane
1987 Mercury Sable won't turn over. Think we got a bit wire-cutting happy. What wiring is needed for it to turn over? Solenoid and battery are good. Is there a free wiring diagram available?
I don't know if there is a free wiring diagram available, but to turn the engine over you will need to purchase or build a bumper switch. A bumper switch can be easy to build and relatively inexpensive. Get two gator clips and a bumper type toggle switch. Connect about three foot of wire to each side of the switch, this will create a broken circuit. Locate the ignition wire which is on the starter, since there has already been a lot of damage to your wiring, one more cut won't hurt. Clip this wire and skin it back and connect one gator clip and then connect the other gator clip to a hot battery, this will create a complete circuit. Switch the car on and push the button, it should turn the car over if the starter good. If the starter doesn't turn over then that may be your whole problem.
Jul 22, 2010 | 1987 Mercury Sable
I have a 1987 Suzuki Dr 600 r Dakar, Was riding wh...
probly blew engine but a top end is not hard to do with a clymer manual-theyr detailed and will make u a pro like us
May 19, 2010 | Motorcycles
Front fender is cracked and rubs, know this is a common problem, is there another fender that fits this bike
Here is a link to a new one but it is $180
http://cgi.ebay.com/ebaymotors/Yamaha-1986-1987-YX600-NOS-Front-Fender-J-M_W0QQcmdZViewItemQQhashZitem48396ec7ebQQitemZ310201206763QQptZMotorcyclesQ5fPartsQ5fAccessories
These are the models it will fit:
Part # = 1UJ-21510-00-MW
Part Description = FRONT FENDER COMPLETE
YX600S 1986 600 YX600 RADIAN Street
YX600SC 1986 600 YX600 RADIAN (Cal) Street
YX600T 1987 600 YX600 RADIAN Street
YX600TC 1987 600 YX600 RADIAN (Cal) Street
To try to find one that would fit the same that is not made for the bike you would have to actually compare your cracked one with the others. If you call a Yamaha dealer they will most likely want to sell you a new one, but they may give you a cross reference for other models that will fit.
Please vote for me and rate me if this helps,
ETRONIC
Mar 15, 2010 | 1987 Yamaha YX 600 Radian
Hi my honda cbr 600 fl 1991 the bike pulls great
im not sure if this model has a fuel pump but follow your fuel line and see if it does wen u find it remove black plastic cap and check the points contact breakers are in good conditon ie not worn uneven or worn out and that they open and close.check your air filter spark plugs and your carbs could have a blocked jet so get them cleaned and balanced.
Oct 25, 2009 | 1987 Honda CBR 600 F(1)H
I lost my ATM card in the washer and was not unable to find it. Now I notice a short grinding sound every once in a while when the machine goes into a fast spin cycle. Obviously, I think it is the ATM card...
What a bummer.... pull the agitator up... it should snap off.. and if you're lucky your card will be lodged underneath....otherwise you'll need to pull this machine apart . you may even need to pull the inner drum loose to access. Start with the simple...pull the agitator..
Oct 17, 2009 | Washing Machines
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
