Question about Toshiba DKT2010SD Phone
I have one phone line in the office and i want to
I have one phone line in the office and i want to connect 2 x toshiba DKT2010F-SD. how can i do this? i have tried using a normal cheap splitter but this does not work.
  • Toshiba Master
  • 2,460 Answers
A couple of things come to mind. As a very minimum, there is a little bit more expensive splitter called a 267-B (vs 267-A) that splits an RJ-14 jack into 2 RJ-11 jacks that the Toshiba uses. For a couple of reasons, I've probably used 3 or 4 267-B's in the last 10 years.
The problem is, it only splits it at one end...at the KSU you need hardware to feed that extension. Normally, it's a single jumper from your cable pair to the block on the KSU. Do you know how to do that? If not, I'd suggest you call your Toshiba service tech.
Carl
Posted on Jun 18, 2009
Have a 3010 SD and only line 1 rings, there are 4 lines.
The telephone has several capacities mentioned as four lines where each would have been networked a separate devices to attain voice communcations. The telephone service provider usually would request to either install at the location several beyound online jack to make possible several entities communcations. Also, the phone with several line becomes useful in situations where several office spaces require communcations sharing from the same telephone. Considering the number of lines that the telephone provider made avilable at the location, the telephone feature buttons can be used to select several lines of choice only that all four becomes tasked when four telephone connection jacks were established.
Feb 15, 2011 | Toshiba DKT 3010 Corded Phone
Wont Ring, Wont pick up another line, upgrading phone lines
You will have to do a little programming to accomplish this. I attached a website to this message that has all the Toshiba manuals. You will have to look at program number 16 for line access and 81 for ringing options. The code to get in program mode is *#*#1*2*3. Hope this helps.
Feb 16, 2010 | Toshiba DKT2010SD Phone
DKT 3010 SD programming mode?
If the phone is on any Toshiba DK system, enter programming mode my pressing the following sequence (without selecting an intercom line, or an outside line, but at the phone's idle state with the handset down) *#*#1*2*3
On a CIX or CTX System, again, at the phone's idle state w/ handset down dial *#*#1*2*3*
Jan 07, 2010 | Toshiba DKT3020SD Corded Phone
Problem adding additional lines to calls
To "jump on" you would need to turn on executive override. Its in Program 30,31,35 in system programming. To conference call simply press Conf/Trn call the extension to conference in with. Have them pick up handest and press Conf/Trn again and you are all connected. More info and your manual can be found here.
http://guides.idacomusa.com/
Jun 11, 2009 | Toshiba DKT2010SD Phone
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
How do I re-program the intercom button on a DKT3210_SD phone
If you have the software you can select to pick up on line 1.
Or we can remote it and change it.
Tony
Mar 04, 2009 | Toshiba DKT-2020-SD telephone
Ipu not found on a toshiba ip series ip5022-sd
Bring the IP phone to the office and connect to a data jack.
if you connect the ip phone is good and you might have a rest. router.
info@ameritelnj.com
Tony
Dec 24, 2008 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2010SD Phone Logo
188 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
