Question about Toro Lawn Mower With Toro Power Tools
Replace pull cord on toro 20331 - Toro Lawn Mower With Toro Power Tools
5 Suggested Answers
SOURCE: toro model 20331 reat wheel drive doesn't work
Download your model's service guide from here:
https://lookup3.toro.com/request/request.cfm
I had the same problem, & was able to fix mine.
Posted on Jun 30, 2010
guru_fixya
  • 944 Answers
SOURCE: Bought the Toro 20331 yesterday.
Take off recoil housing usually which as around 4 bolts.
unwind recoil spring by rotating the plastic disc backwards.
There will be a knot be sure it is tight.
The spring is jammed at the recoil housing you need to release it.A spring acts to give tension on the cord so we can pull to and fro.
I have a Toro lawn mower video this is a common one.So you can understand what actually happens and how it is linked.
Picture for explanation:
http://redhouseon7th.com/redhouse/howto/2008ToroPullCord/index2.html
video for explanation:
http://wn.com/Fixing_the_pull_cord_on_my_toro_mower
manual for more use:
http://dl.owneriq.net/b/b0950759-2fe3-c994-a1c7-c06acfd5101f.pdf
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 26, 2010
e-Guru
  • 3917 Answers
SOURCE: I have to replace the
The black cover on the front of the mower is held on by couple of screws from underneath. You have to remove the cover which will give you access to where the cable connects to. Then use a pair of pliers to squeeze the end of the cable to disconnect it from its mounting hole. Now loosen the cable clamp, pull the cable downward to remove all the slack then push the cable jacket up 1/8" and secure with the cable clamp.
Posted on May 25, 2011
SOURCE: what is wrong with the toro push mower pull cord if it will not pull out?
I would say check the bolts that hold down the pull cord they are the same thread as the cover bolts but the cover bolts are a tad longer and if used on the pull cord housing they stick down to far and hit the fan blades on the magneto and it will not rotate
Posted on Mar 27, 2012
Where does the armature spring attach to for a toro 20331 mower
Using http://www.partstree.com/parts/?lc=toro&mn=20331 and your serial number you should be able to locate the parts diagram for your mower. This may help you with your problem.
Sep 03, 2013 | Toro Garden
TORO Model 20331- Serial NO. 312000001 and up
check for spark then check carb for clean gas
Aug 21, 2012 | Toro Garden
Toro model 20331
I have a toro mower and it has same problem,my husband replaced some parts&it worked but then started same thing again,he hasn't had time to mess with it again seeings hes been working reg. job&every other spare minute been spent trying to fix our truck! Id love to see an answer for mower to help this person&us also!!
Aug 17, 2012 | Toro Lawn Mower With Toro Power Tools
What is wrong with the toro push mower pull cord if it will not pull out?
Mar 11, 2012 | Toro Lawn Mower With Toro Power Tools
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
Toro model 20331 reat wheel drive doesn't work
Jun 28, 2010 | Toro Lawn Mower With Toro Power Tools
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Model # 20331 Starts, but doesn't run
Mr. Fixit...excellent advisement...really appreciate it. It got my grass cut today. Big yard! Problem is, when I finished, now I have the same problem with it not running...what do you think: take the Toro to the junk yard or what? Thanks!
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
139 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
