Question about Garden
Ironing board how to open the iron board
jackboy
  • 2985 Answers
SOURCE: need way to open the iron 3302
Usually start at the cord end to locate internal screws to get top off then down to the next layer
Posted on Aug 01, 2007
oscarn
  • 109 Answers
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Posted on Sep 21, 2007
SOURCE: iron leaks water while ironing
Seal on iron is disolved. replace iron
Posted on Aug 31, 2009
Testimonial: "your information was very helpful."
SOURCE: Need the circuit board for a DE-871A Iron / Iron does not turn on
The electronic shutoff light blinks but won't stay on, so the iron won't get hot. Can this be repaired? Can I disable it?
Posted on Jun 13, 2010
SOURCE: Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Posted on Jul 25, 2010
Rowenta iron leaking
Irons that develop this type of leakage usually have to be replaced.
Dec 08, 2013 | Irons
Reset singer iron
1) test the power cord
2) no power to receptacle
3)open thermostat
4) open the heating element
5) defective main switch.
6) if you iron has electronic control the board can be faulty.
see the diagram
God bless you
Sep 09, 2012 | Singer ESP2SB Iron with Auto Shutoff
My iron will not turn on....what's wrong?
Welcome to Fixya. If the iron wont turn on it can be caused by a faulty cable, a busted Fuse, transistor, capacitor, switch problem or the main board of system. If you have warranty then you can have it checked an repair for free or if you have knowledge with electronics then you can open the iron and check hte part that is bad
Thanks
Jul 29, 2011 | Rowenta Power Duo Iron
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Dec 14, 2009 | Rowenta Professional DE871 Iron
Autoshut off red light keeps flashing
I had the same problem and eventually removed the tilt sensor. This is the molded board that you see when you open the back of the iron. By removing it, you will also loose the timer off function. The thermostat will still be operational.
Oct 14, 2008 | Braun SI6285 Iron
Handle on iron gets too hot to hold onto. Product is an Euro-Pro Ironing Solution. Ironing system includes the iron and ironing board together.
I purchased a silicone heat protector for a pot handle and sewed it together with dental floss around the iron handle
Sep 23, 2008 | Euro-Pro EP1005 Iron
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
