Question about AMS Tech Roadster 15CT PC Notebook
It doent work
What memory ram should it have it has two slots it is a AMS TECH ROADSTER 15CT MODEL SY15-T60374 pins and size also what type off harddrive does it have. A freind has gaven to me to keep but it was working fine befor he took the hard drive out
  • 53 Answers
Download a program called everest http://www.lavalys.com/products.php?lang=en&page=11
it will show u every thing .
Posted on Jun 18, 2009
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
Ams tech rs15CT what can i do with it, can i upgrade parts or should i just toss it
Remember it is booting from a CD and the speed of your CD has a big impact. Once you get it installed it will operate much faster.
Jun 18, 2014 | AMS Tech Roadster 15CT PC Notebook
I WANT TO UPGRADE THE GRAPHIC CARD ALSO THE RAM CAN YOU PLEASE TELL WHICH GRAPHIC CARD AND RAM WILL WORK ON MY MOTHERBOARD? Model Name : 8LD533 M/B Rev : 1.X BIOS Ver : 6.00 PG Serial No. :...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
My older AMS Roadster 15CSA needs a memory upgrade to 64 mb. Is this even possible? Is the manual even still available? Thanks, Tom
Hi, not only is it possible, here is a link to a website that has the memory on sale for you!!
http://www.thefind.com/electronics/browse-ams-roadster-15-series
Looks like the price is 43.88 for the 64mb module.
I hope this helps you out, and good luck !!!
Mar 14, 2011 | AMS Computers & Internet
I have an IBM NetVista PC model #830781U and want to install additional memory...1GB chip... How do I do it??
Ok, first of all before installing the ram, you want to make sure the ram you are installing into your computer if the motherboard support the type of ram chip you are installing it in. For your model it is ddr184 pin After this, you can take out your case panel which is the left side by unscrewing the 2 screws in the backside of the panel. Carefully take the panel apart from the computer and set it aside. What you want to located is the RAM slot on your motherboard which typically is 2 slot next to the cpu which has the big fan. Most likely one of the slot or both of the slot is already accompanied by the old memory chip. There are two hinges one on each side, bottom and top. Push these pins down and it would loosen up the memory chip that is already installed on. Replace the new memory chip and make sure you align the golden tooth pins extacly to the memory socket and then push down on the chip until it clicks. Test your computer if it works, if not. You computer may not support the memory chip.
Jan 13, 2011 | IBM NetVista PC Desktop
I need to know the capacity for MEMORY AND THE TYPE SPECIFIED
According to the manufacturers specs these are the memory specifications you need, and the maximum the motherboard will accept...
3 x 168-Pin DIMM-socket
for up to 768 MB memory SDRAM
with 8, 16, 32, 64, 128 and 256 MB size
Dec 28, 2010 | Shuttle Slot A AI61 (MBAI61) Motherboard
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Ineed windows 98 plus for ams tech
Get yourself utorrent, the best bittorrent client, from, www.utorrent.com then go to www.thepiratebay.org, when there in Search, simply type in Win 98se, and download the torrent, burn to CD. and you can then use it.
Mar 02, 2010 | AMS Tech Roadster 15CT PC Notebook
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mike
Mar 22, 2009 | ASUS P4S533-MX Motherboard
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
AMS Tech Roadster 15CT PC Notebook Logo
Top AMS Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an AMS Computer and Internet Expert? Answer questions, earn points and help others
