Question about Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr
My electric indoor smoke alarm won't stop pipping every 30 seconds?
Not sure if this is the right one but it won't stop pipping out loud!!
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
Usually indicative of low battery. To locate the device, try using a piece of tape to cover the sound port. You'll know you've found the right one when the sound level changes. Don't know, but I'd bet there's more than one chirping as well.
Posted on Nov 19, 2014
3 Suggested Answers
SOURCE: kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Posted on Feb 28, 2010
  • 4736 Answers
SOURCE: Our smoke alarm with battery
You didn't mention if you had replaced the battery, yet. If you haven't, then that's more than likely the problem. Also, it probably needs cleaning. You can accomplish this by using canned compressed air (like you clean your computer with). Use the straw nozzle to reach all the nooks and crannies. Clean after removing the old battery and before installing the new battery. Batteries should be changed annually and at the same time clean the unit. When using the canned compressed air, try to keep the can in the upright position, as much as possible.
Posted on Jan 25, 2011
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
I have the Firex i4618, after changing the battery it continues to chirp, have tried 2 new Duracell proper model batteries with same result.
Smoke Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon: Amazon com Smoke Alarm. I hope this helped you. Have a nice day
Jan 06, 2013 | Kidde Firex I4618 Smoke Alarm W/battery...
Rental mgmt company just installed Kidd 112020/40/80 (don't know which one. It does the same thing the previous smoke alarm did - wakes me up in the middle of the night! It chirps every hour, every 30...
They only chirp for two reasons:
1. The sensor is past its useful life and needs replaced
2. There is a power issue with the battery. Even the ones that are hardwired into the electrical system need a battery.
Jun 23, 2017 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
3 smoke alarms are beeping ever every 30 seconds and all batteries are new and secure, reset button was pushed and still they beep
usually the problem is battery,make sure that ur battery is not expired..try to reverse the battery like positive to negative then put it right..
Sep 07, 2010 | Vacuums
Home security alarm keeps beeping
Most wired-in smoke detectors work off of two sources of power, electric and battery. If the beeping occurs every 30 seconds or so it most likely means you need to replace the battery in the detector. On the other hand if by beeping you mean the alarm is going off, I would first try cleaning the unit with your vacuum. If that doesn't solve the problem then the next step would be to replace the unit. Hope this helps.
Apr 08, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kiddie fire alarm model I12060, beeps once every
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
A/C motor smokes and stops about 30 seconds after i turn it on
How may times have you tried this then? lol if I were you I would ask an A/C Engineer to pop round and check your supply to the system, and all other electrical systems. Please stop what your doing its quite obvious now there is a fault on the site.
Be safe.
Steve
May 25, 2009 | Coleman Mach III Air Conditioner
Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr Logo
184 people viewed this question
Top Kidde Home Experts
Tre Elkins
 Mikey
Mikey
Are you a Kidde Home Expert? Answer questions, earn points and help others
