Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Motherboard Sound Drivers for model: KS-AX 4302
Update graphics device foram1100-e1302b
All downloads for Acer computers are to be found at www.acer.con, specifically
http://www.acer.co.uk/ac/en/GB/content/drivers
Your model is a Desktop > Aspire > M1100
It will ask you what O/S you are using, because the drivers you need, in general, depend on that.
13.April.2014
Feb 02, 2014 | Acer AOpen AX 6BC Pro (91.87810.A03)...
I need drivers for Evga motherboard 112-ck-nf75-k1. I can't find them on Evga website. Please help.
Click on the link below, and select Mainboard fron the left hand side, then select Evga 730i/730a/630i/610i from the middle and then your operating system from the right hand side.
Your board is the 630i model
http://www.evga.com/support/drivers/
Regards.
Dec 14, 2010 | Evga (131-K8-NF44-AX) Motherboard
I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
May 21, 2010 | Lexicon Omega Pro Studio External Sound...
How do i turn my protector light off of my amp?
I'm not really sure how your amp works but i can tell you that if that light is on there is probably something wrong. Check your ground wire. Also it could be your not getting enough power to your amp, or too much
Mar 06, 2010 | JVC KS-AX7300 Car Audio Amplifier
No sound
Here you will find the drivers:
http://www.evga.com/support/drivers/default.asp?switch=2
The following drivers/files are available for your hardware and operating system combination.
Note: If you are having difficulties downloading the driver file, please make sure you completely disable any third party download managers.
Driver Version : 15.17 - EVGA Recommended Download Auto Installer : YES WHQL Certified : YES Driver File : 15.23_nforce_winxp32_international_whql.exe Notes : NONE << Select a different driver
Dec 19, 2008 | Evga (131-K8-NF44-AX) Motherboard
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
How 2 find sound drivers in the site?
I need a sound driver for P4S133-VM model. I need to download a driver.
Sep 20, 2007 | Intel Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
