Question about Toshiba Satellite P25-S607 Notebook
Screen dosent display
My computer turns on but i cant see anything on the screen, but you can turn the brightness up and down and still nothing on the screen
  • Alan Berris Nov 18, 2007
    Similar problem but only occasionally. The screen will work for a while and then fade to black. Leaving it off for a few hours sometimes gets it back on. Sounds like an electronic problem (capacitor?)
Screen goes blank
Posted on Jun 20, 2010
    Problem Solver:
  • 10 Answers
If your laptop still turns on but doesnt display. change out the fl inverter. if that doesnt fix it then its your lcd screen. but i suggest first changing the inverter.
Posted on Nov 02, 2007
My daughter turned down the screen light too far, cant see screen, how do i fix this
it happened to me when i mistakenly turned down the brightness and i thought i had ruined it. It took me days to realize that i needed a flashlight on my i phone to see on my Kocaso tablet go to settings from there go to display and adjust the the brightness from zero to 50
Jan 28, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My Olympus DM-420 digital voice recorder does not show information in its display screen. When turned on the display goes on bright white with no information. Unit has to be operated with its visually...
this might be a operating system error. try resetting it. there should be a small hole on your device big enought to fit a needle thru it. if this dosent work connect the device to your computer. if this dosent work contact the manufacturer
May 03, 2011 | Olympus Dm420 (2 GB) MP3 Player
Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
Apr 03, 2011 | Computers & Internet
Laptop will not display screen although is turned on.....
I assume you are saying the screen is totally black, not blue. If it is totally black there can be a large number of causes. It is hard to give one simple answer. It could relate to the brighteness of the screen, the display, the logic board, the graphics card or even a problem relating to updating Apple firmware, You could try some simple things first.1) If the lighting on your computer is accidentally turned all the way down, your screen will be black! To turn the brighteness up, push F2 on the top of your keyboard and click until the lighting improves and you see the screen. If your display stays black it could be an indication that you just need a new Display. They do wear out. 2) Another thing to try is to start the computer in Safe mode. As you push the power button hold the shift key down. This can sometimes help resolve issues relating to startups. Also, if your screen stops being black it is an indication there is nothing wrong with your display. 3) You could try resetting the PRAM, This can also help with a startup issue. 4) Some specific models of Macbook Pro computors have issues caused by the NVIDIA graphics card, which Apple knows about and apparently will repair, possibly free of charge. My suggestion if none of this helps is to take it to a Genius bar at an Apple store for them to troubleshoot. That, in itself, costs nothing. Other suggestion search with google for further answers from other Mac owners!
Jul 14, 2010 | Apple MacBook Mac Notebook
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
Laptop problem
Hi George you may have the brightness turned down or The screen turned off Press FN Key and F4 if this dosent help
Try FN Key and F5 and do it slowly give it a second or 2 to happen Try looking pge 3.8 at special keys in your manual and try these
Hope this helps if it dosent try and restore your OS by pressing F9 when starting then see if the screen comes up if this doesent work you may have a screen Lighting inverter problem
let me know
Feb 16, 2009 | ASUS Eee 4G Notebook
Brightness display comes on by itself and won't turn off
1. Adjust the LOT screen preset.
2. Trace the G1 path , LOT to neck board. Sum times diode are capacitor problem.
3. LOT sarounds one 10Mf / 450 V capacitor bad
Oct 14, 2008 | HP mx705 17" CRT Monitor
Nuvi 200 screen is extremely dark
The screen brightness could be turned down or the display itself is defective. Even if it was turned down all the way it should be somewhat visible, so if the display is completely blank, I would suggest that the LCD display has become defective.
- Jim
Sep 29, 2008 | Garmin nuvi 200W GPS Receiver
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Toshiba Satellite P25-S607 Notebook Logo
232 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
