Question about HP Mini 1000 Netbook
Netbook how do you fix a hp netbook that has slow internet?
Runs very slow
Primary respones to fix your slow netbook:
1. Clean all Temporary Internet Files
2. Clean the registry.
3. Remove malware.
4. Transfer all unnecessay downloads to an external device.
External hard drives are cheap....available for less than $100.
The more files you have on the netbook, the slower it runs.
Feb 16, 2013 | Dell Inspiron Mini 10 Notebook
Hp netbook is running so very slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Jan 17, 2013 | HP Mini 1000 Netbook
My acer netbook was working fine with connecting to the internet, until last week - no stating no connectivity. Tried to reset system, but still not working - also very slow
You might've hit the button that turns off wifi. Check to see if you did that.
Also for slowness. Download malwarebytes (google it, its free) and ccleaner. Run both of those and cleanup your system. That should make a difference.
Mar 01, 2011 | Acer Aspire One Netbook
Hp mini 210 too slow
Well, the issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try http://www.speeduphp.com/speed-up-slow-hp-mini.html to give a free & full scan of your slow HP PC to find & fix all possible issues. Best regards!
Feb 18, 2011 | HP Mini 210-1030NR Netbook
I just purchased the sylvania synet07526 7" netbook and this thing is sssooooooo slow. Is there anyway to speed it up, or download xp from the internet? Please help.
This notebook can be considered a toy, as it will not do much than connect to the internet with a limited view. It is slow compared to a modern desktop or a laptop as the processor is limited. The fact that it connects at all is a miracle. There is no known way that this device can be sped up as you cannot add to the machine.I would suggest that you go to digitalgadgets site and down load the update to the Wifi at http://www.digitalgadgets.com/netbooks/update.html.
The update works much better.
Nov 27, 2010 | Sylvania G-Netbook
My netbook runs slow and freezes
There are many reasons for slowness and freezing. Computer specs (ram, processor speed, connection speed)) could be not enough for today's internet.
Internet cache, temporary internet files, temporary files should be cleared.
Try defragmenting the hard drive.
And try downloading a program like CCleaner from Piriform.
Apr 10, 2010 | Computers & Internet
My hp mini 1000 netbook is very slow.
There are a number of reasons that may cause your HP Mini running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/speed-up-slow-hp-mini.html to free detect and fix related issues.
Nov 10, 2009 | HP Mini 1000 Netbook
G netbook cursor speed
Hello my name is Tim Ehrhart, to slow your cursor speed go to controll panel and click mouse, then click pointer options and adjust the pointer speed. I hope this helps you and please leave feedback as I am new and am trying to gain a awesome rep.
Mar 16, 2009 | Sylvania G-Netbook
HP Mini 1000 Netbook Logo
22 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
