Question about Saeco Syntia Espresso Machine & Coffee Maker
Spanner 15 symbol appears
Spanner symbol appears
A spanner symbol appears when I switch the engine on, the car beeps a couple of times, then symbol goes, beeps stop and I drive. The coolant seems to need replacing very frequently, but it's too wet w
Your water pump is bad,better fix it asap or your engine will mess up and cost more money.Look under vehicle after it has been parked awhile and you will see leak on ground.
Jan 19, 2014 | Citroen Cars & Trucks
I have a spanner symbol on my 407. what does this mean??
You need to carry out the periodical car service due (e.g. engine oil & filter, air filter, fuel filter, cabin air filter). The "service" spanner symbol "reset" button is placed on the lower right corner of the dashboard. See picture below:
Then you should reset the "service" spanner symbol by pressing on the "reset" button on dashboard, when ignition key is in OFF position. Hold the button pressed and turn ignition key in ON position. Hold the button pressed and see on the dashboard successive numbers will appear: "10", "9", "8", ... , "1", "0". Then release the button and switch OFF the ignition key. The "service" spanner symbol followed by "20000 km" (or "30000 km" depending of the engine type), will appear for few seconds after turning ignition key in ON position, and will dissapear after engine starting. The car service due was reseted.
Please do rate my response. Thanks!
Feb 21, 2011 | 2005 Peugeot 405
Garmin 1490 LMT came from box with foreign language. How do I change it to English?
On the bottom right corner of the screen which has WHERE TO and VIEW MAP there's a spanner symbol.
  • Press the spanner symbol
  • This brings you to another screen. Press SETTINGS (the spanner symbol) of if it doesn't have a spanner symbol press LOCALE (the blue symbol)
  • Press LANGUAGE (The lips symbol)
  • This takes you to a screen with 3 items on it; VOICE, TEXT LANGUAGE and KEYBOARD
  • Press VOICE and select an English speaking voice. Press TEXT LANGUAGE and select English or American English if you're in the USA.
This should solve your problem.
Jan 29, 2011 | Garmin nuvi 1490T GPS Receiver
How to reset back to english language
  • Press TOOLS (The spanner symbol on the screen with WHERE TO and VIEW MAP)
  • Press SETTINGS (The spanner symbol) or LOCALE (The blue symbol) if your satnav doesn't have the settings symbol
You'll come to a screen with 3 items, VOICE, TEXT LANGUAGE and KEYBOARD
Press VOICE to change the voice to English. Select a voice from an English speaking country.
To change the text to English press TEXT LANGUAGE and select English.
Dec 16, 2010 | Garmin nuvi 1350 Car GPS Receiver
How do i reset the service spanner symbol on my aprilia 125 leonardo sport city scooter
Ok, disconnecting the battery does NOT reset the service light. To reset the service light (spanner symbol) on dashboard you must hold the mode button for about 5 seconds with ignition OFF then while still holding the mode button turn ignition on, continue holding the mode button for a futher 10 - 12 secs and then it should just disapear. This solution was brought to by RPMs. Mobile motorcycle service.
Oct 30, 2010 | 2007 Aprilia Sportcity 250
How do I change the language to English?
  1. Press TOOLS (the spanner symbol in the right bottom corner of the screen which shows VIEW MAP and WHERE TO)
  2. Press SETTINGS (The spanner symbol) or LOCALE (The blue symbol) on models that don't have a settings symbol
  3. Press LANGUAGE (the Lips symbol)
You will see a screen with 3 items on it. VOICE, TEXT LANGUAGE and KEYBOARD
If you need to change the voice to english press VOICE and select an English voice.
If you need to change the text language press TEXT LANGUAGE and select English or American English if you're in the USA
Oct 06, 2010 | Garmin nuvi 255W GPS Receiver
Just received new Garmin Nuvi 265. Not as yet connected to car. All titles in German
Press TOOLS the spanner symbol
Press SETTINGS the spanner symbol
Press LANGUAGE the lips symbol
You'll see 3 items one for Voice language, one for Text language and one for Keyboard.
Press the Text Language one and select English.
Sep 25, 2010 | GPS
Language in arabic and can not get back to english
  1. Press TOOLS (the spanner symbol)
  2. Press Settings (the spanner symbol) or LOCALE on some models (Blue Symbol)
  3. Press Language (Lips Symbol)
  4. You'll see 3 items. One for Voice Language, one for Text Language and one for keyboard.
  5. If you need to change the voice to english Press Voice Language and select an english name.
  6. If you need to change the text to english press Text Language and select english or American English if you're in the USA
Sep 21, 2010 | Garmin nuvi 255W GPS Receiver
It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Apr 01, 2010 | Whirlpool Washing Machines
Re start problem
What is the Manufacture of the machine and the model number.
Without this information, there is no way to supply any suggestions.
Get back to me with those 2 items.
Thanks
Mac
Mar 28, 2008 | Office Equipment & Supplies
Saeco Syntia Espresso Machine & Coffee Maker Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
