Question about Zenith VR4206HF VHS VCR
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr is hooked up to my tv via RCA cables. I'm trying to record a program I have saved on my tivo. When I watch a vcr I have to switch my tv to the audio channel. It seems my vcr is recording the audio channel and not the program I am watching on the tv. how do I correct this problem. Thank you for any help.
  • 3 Answers
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Posted on Jun 18, 2009
Can I record VHS tapes to my TiVo model TCD649080?
Sure, just plug the output of the VCR into the input on Tivo. Set the Tivo to Channel 0 or 1, hit play on the VCR and then Record button on Tivo. Stop recording when the tape (or portion of) is finished.
Mar 04, 2011 | Tivo Series2 TCD649080 Video Recorder
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Jun 18, 2009 | Zenith VCS442 VHS VCR
How to connect cable tv, dvd and vcr together and tivo, too
go to tivo.com they have all possible connections available.
pt
Jan 16, 2009 | Tivo Series2 TCD649080 Video Recorder
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Recording a tv show
Make sure the cables going from the cable box to the vcr are not loose as well as the ones from the vcr to the tv.
Feb 20, 2008 | Zenith ALGB201 VHS VCR
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Problems with DVD/VCR Player and Tivo
How are you attempting to connect this? Can we get more information, such as your TIVO model and TV model?
Jan 13, 2007 | Zenith ZRY-316 Video Recorder
Televison & Video Logo
173 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
