Question about Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner W/ Dual Layer Support (GSA4120) Burner
I have Hitachi-LG GCC-4240N need the 68 pin configurationto connect that divace to standart IDE or E-IDE
    President:
  • 828 Answers
Use standard,...
Posted on Jun 18, 2009
Can you run the Hitachi-LG GCC-4482B in a windows 8.1 machine?
Okay, quick question; as inexpensive as DVD/CD writers are Nowadays, why would you want to use something so....outdated on a WIndows 8 Machine? Oh nevermind; it would take too long to explain and your brain obviously can't handle the input as of right now. YES you CAN use it on a Windows 8.1 machine. The Machine will LIKELY have SATA ports on the motherboard, so you would have to probably get an IDE to SATA Adpater Card.
Feb 27, 2014 | LG " HITACHI GCC-4482B 48X/32X/48X/16X IDE...
Tip
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
on Sep 12, 2010 | Computers & Internet
In the boot device menu, drive 1: no ide device what does this mean?
test for secure dust free connections or replace the 40 pin ide lead from mother board to hard drive
include electrical extensions
operating system cant find ide hard drive
hope it helps
Nov 12, 2011 | Dell Dimension 3000 PC Desktop
Cannot copy files, pictures ,or anything onto CD ROM. Tried different brand of blank CD (Maxell CD-R) and still cannot transfer any files. My other computer with the same drive will not recongnize the...
If a problem on 2 x pc's then its probably a drive issue.
Does it play CD/DVD's ?. If not you could try a CD lens cleaning disk, it may just need a good clean out.
As you're moving it between PC's then the IDE cable is probably connected properly.
My only other thought is that it is faulty, probably not worth repairing, you can get dual layer DVD/CD rw drives for under £15 on ebay.
Jan 02, 2011 | LG (GCC-4240N) CD-RW/DVD-ROM (Combo)...
I need the link where i can find my Hitachi-LG GCC-4240N 68 pin conn and if it used ad standrd EIDE.
I find in one of the Cable compny the pinout configuration and the EIDE pinout configuration.
to boulit a cable is very simple if you have all the data.
AnyWay Thank you
Azi
Jun 19, 2009 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
My dvd plays cd but not dvds
Try using a good quality dvd cleaner first. If that does not fix the problem then it is an optics issue for the dvd & it would be cheaper to replace the drive than to try & have it fixed. Hope this helps.
Mar 30, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Config HL-DT-ST RW/DVD GCC-4240N HITACHI
did you play a cd that install own player ? becaouse if you did this program messup your cd/dvd happen to me e-mail me if you still have problems
Mar 29, 2008 | Microsoft Windows XP Professional With...
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
My LG Combo is not working after i have installed another LG Dvd Writer
I am assuming they are both on the same ide cable. If so set both of the jumpers to CS (cable select) and try rebooting the machine.
If this doesnt work you might have the bios configured to say there is no drive on that ide channel location. If the first option doesnt work let me know and I might be able to help further
Feb 11, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
118 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
