Question about Sierra Online, Inc. X-Files: Resist or Serve for PlayStation 2
Sculy is in the firehouse how do i get in their or around the back of the place
  • 3 Answers
Mulder and Scully will call each other and resolve to meet
at the fire station, so go ALL the way back to the area
with the Sheriff's Office and towards the red brick building
in the corner. After a cute cutscene, Mulder and Scully will
be separated again.
-Fire Station-
Walk toward the fire truck and find a body in the corner.
Examine it for the Firehouse Key. Go through the only door
in here and kill the zombie inside. Look on the desk for
some Magnum rounds and continue on to the next room, and
the room after that.
Go into the bathroom just south of here and kill this guy
for some more Magnum rounds. Enter the room to the north,
then go through the double doors right next to you since there's
nothing of interest here. Go through yet another pair of
doors to the left and then, being the nice young lady you
are, kill the burning guy in here. Pick up the First Aid Kit,
then go out the doors with the EXIT sign.
As soon as you walk into the next room a dog will come after
you. Kill it because it sucks, then investigate the firemen
suits for a Rag. Go out the door and down the street,
killing some more dogs. Eventually you'll find the Shop
Easy and Mulder.
After the cutscene, Mulder rejoins you. Save your game
and go inside.
hope that helps.
Posted on Jun 27, 2009
When did the Firehouse in Kansas City Missouri close
look up in public records for the firehouse information
Apr 30, 2017 | Miscellaneous
Got a F150 5.4 Trriton smelling gasoline thru the vents , plugs and injector O rings have been replaced
Check the lines from the engine to the tank. Were the metal clips on top of the injectors put back on. You might have to pull the plenum back off to see if is leaking under it. Sorry to say, I have seen mechanics not put the clips back on. The clips are there to keep the injector from being pushed up in the fuel rail and not letting bottom seal.
Dec 18, 2016 | Ford F-150 Cars & Trucks
Rear facing car seat in a pontiac bonneville
If you go to any firehouse they will show you how to install the seat free of charge, the police station does this as well. Call ahead to see which one does the public service.
Jun 28, 2012 | 1999 Pontiac Bonneville
Need to install memory on a veriton Z290G desktop but dont know how to open the computer
1 Turn off your computer and all the peripherals connected to it before
opening it. Then unplug all cables from the power outlets.
2 Place your computer on a flat, steady surface. If your computer is in the
vertical position, rotate the plastic stabilizers and lay your computer on its
side.
3 Turn the screws counterclockwise to release the cover.
4 Hold the sides of the cover with both hands.
5 Slide it back about an inch and then gently lift it upward to detach it.
6 Remove the side panel.
7 Locate the memory DIMM socket on the mainboard.
8 Press the holding clips on both sides of the memory DIMM socket outward
to release the memory DIMM (a). Gently pull the memory DIMM out of the
socket (b).
9 Align the memory DIMM with the socket. Press the memory DIMM into
the socket until the clips lock onto the memory DIMM.
The memory DIMM sockets are slotted to ensure proper
installation. If you insert a memory DIMM but it does not fit easily
into the socket, turn the memory DIMM around and try to insert it
again.
10 Align the cover's hinges to the housing frame; then gently push it in to
slide it back into place.
11 Secure the cover with the screws.
Oct 03, 2011 | Acer Veriton Z290G 185 320GB
How do I remove the horn assembly and air bag on a 2209 corolla. my daughter dropped a quarter in behind there?
Much care needs to be exercised when working on / around the air bag to prevent accidental deployment. For example, an electrostatic discharge from your body can deploy the airbag.
If you're not experienced / comfortable doing jobs like this, I'd suggest taking it to a shop.
The procedure is roughly ::
First disconnect the battery ground (negative) cable and wait 30 minutes before beginning -- this will reduce the probability of deploying the airbag (allows capacitors to completely discharge).
There are 2-3 recessed screws on the back side of the steering wheel -- remove these. The center of the steering wheel should then come off -- if it doesn't check for other screws.
If you need to remove the airbag, the wire leads will have to be unplugged.
You might be able to remove the coin without completely removing the airbag.
Here's a link discussing airbag deactivation ::
http://www.firehouse.com/forums/archive/index.php/t-19555.html
Charlie
Feb 22, 2011 | 2009 Toyota Corolla
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Our fire station has a cat5e cable supplying internet access to our internal network from a switch in city hall. It connects a baystack 350 to their switch. If this cable is left plugged in during the...
Very likely an IP problem. The server in City Hall is most likely doing the DHCP assignments for all connected machines, and if there is a LAN server running DHCP also in the firehall, there will be a conflict, which may not manifest itself until the assigned IP leases expire and renew. If this is the case, try a router WITH DHCP DISABLED between the two systems, WAN side toward City Hall. As a quick test, disconnect the cable and run IPCONFIG on a firehouse machine. Note the IP, it should begin with 10, 172 or 192. Reboot the machine, run IPCONFIG again. If the IP comes back, you have DHCP running on something. If you see something like 169.254.???.??? you do not, in that case try hooking up a router configured just as it comes from the box. If anything in the firehouse is wireless, making connection thru a wireless router, the problem may be a simple miswire. WAN side toward City Hall and one of the ports toward your switch, don't use the other three. May need to use the uplink port or a crossover cable between router and switch. (Network admin by day, DJ by night)
Sep 11, 2008 | Computers & Internet
Water won't turn off.
This can be caused by a faulty start switch, a bad flow control board or a solonoid valve sticking. they all work together, so any one can do it. You can test the start switch by hooking a VOM across the contacts, press the button momentarily. power should only go through the switch when pressed. You cantest the solonoid valve by removing the wires off of it and check for continuity across the two poles with a VOM.
Aug 18, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
The belt on my turn table came lose
01- Remove the rubber cushion.
02- Remove the Turntable Platter
03- Place your drive belt around the ridge inside the platter
(Make sure that it is not twisted)
04-Place your Turntable Platter back on the unit
05-rotate your platter until you can see a brass knob through one of the round holes in the turntable. (Your belt must be placed around the brass knob) The best way is to take a toothpick and carefully slide it under the drive belt and then pull it out enough that you can place it around the knob. I had the same problem and the above works. If you still have problems getting it back on contact me 352-377-1828......
May 03, 2008 | Teac P-A688 Turntable
Sierra Online, Inc. X-Files: Resist or Serve for PlayStation 2 Logo
121 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
Charles Applebaum
Level 1 Expert
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
