Question about Home
Cannot set model 3144480 time on clock
I cannot set the time on model 3144480. It is way fast but I cannot change it. Please help.
5 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: HP compaq d530c timer running fast
you may check and see if it's set to the "internet time" -> "automatically syncronize with an internet time server", if there you have a wrong server, then it'll reset your time wrong, or if you have another timezone set in windows, than it'll update to that timezone.
secondly, if it's a hardware related issue, than it can be the battery
Posted on Jan 09, 2008
SOURCE: setting clock
I think I solved the problem, take out the batteries and reinstall and then reset, seems to be doing ok now.
Posted on Nov 02, 2008
SOURCE: how to change settings of Seiko world time alarm & desk clock
I have the user manual for this clock for anyone who sends me his e-mail address.....
indysandy@indy.rr.com
Posted on Mar 28, 2010
SOURCE: my clocks time automatically set
What you need to do first is place your cursor in the bottom right hand part of the screen, right over the date and time stamp. Right click your mouse, and a option menu will appear. Click on the "adjust time and date." A window should then open with options on setting you time and date. Click in the little box where the time is, and you can select and manually change the numbers to the correct time! Hope this helps and if you have any other questions, please post back!
Posted on Sep 02, 2011
How do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
Changing the clock/internal time
The clock settings should be set to Auto so that the clock is set by the broadcasted signal; this will automatically update when the clocks change.
Note that Recording start and end times should be set to On Time to ensure that the broadcaster's start and end signals are used. If either of these are changed, the timing becomes manual, and functions such as Series Record are not available.
Mar 06, 2014 | Humax PVR9300T HD DVR
I have model cd 3424 and cant set clock
This was taken from a radio similar to yours. Same brand but different model. Hopefully it'll help.
(Also the "SEL" button it talks about is a big round button/knob on the right of the unit.)
Setting the Time
This receiver uses the 12-hour display notation.
1 Turn [SEL] button to select CLOCK ADJ.
2 Press the [SEL] button.
The clock adjustment mode is activated.
3 Turn [SEL] button to display the item to be selected for
adjustment.
Hours, minutes or exact hour will be switched each time the
button is turned.
4 Press the [SEEK / FAST] button.
[SEEK] button: Turns the time forward.
[FAST] button: Turns the time back.
To set the clock to 0 minutes, 0 seconds (an exact hour),
press the [SEEK / FAST] button.
For example:
At 3:29: Pressing the [SEEK / FAST] button returns to 3:00.
At 3:30: Pressing the [SEEK / FAST] button advances to 4:00.
5 Press the [RTN] button.
At this time, other adjustments can also be made in
Function Mode.
6 Press the [FUNC] button to exit Function Mode.
Mar 02, 2011 | Eclipse CD3422 CD Player
Need to reset the time display on a equitytime model 40009
This solution from the answers below worked on my model 40007 clock today: If you hold down the button on top that says DST for like 10 seconds it will allow you to force change the time.
Thanks. wd 11/21/2010
Mar 15, 2010 | Equity Time USA Insta-Set 44200 Clock...
I plugged in my Brookstone Smartset alarm clock and the wrong time came up. I tried to click on the time zone button to change and nothing happened. What to do?
Brookstone Clock Radio Model CKS5369
Time is set using the RH button on the Month/Date, Time, and Year buttons. If you are only setting time, press the Time button and hold it down while pressing the Tuning/Set buttons for a lower or higher time. If you hold the Tuning/Set button it will shift to a fast change or press and release for one number change. Be sure to note the AM or PM light to the left of the time display.
Aug 17, 2009 | Brookstone SmartSet Alarm Clock
Good Morning. I was given this alarm clock which is driving me crazy cause i cant figure out what to do. I tried researching the internet for a manual, but failed. It is a RCA CD Clock dual wake Radio....
Following are the instructions for the RP5610 which looks very similar to the 4801A (that I also have). The only difference in the instructions is that the 4801A doesn't have a clock icon, just press the SET button until the center colon dots are flashing, Press the rewind or fast forward arrows on the circle next to it to set the time. Set the alarms by pressing the set button until bell 1 or 2 is displayed. Nap is also set with the set button - not sure how to stop it yet.
To set the clock:
  1. Press the SET button until the clock icon is displayed (circle with hands at 10 and 2)
  2. Press |<< REV or >>| FWD to set the time.
  3. AM or PM icon will show besides the time.
Dec 24, 2008 | RCA Radio Alarm Clock
How to change the time on clock radio
I'm not 100% sure if this is right or not, but i used to have one similar and the way to reset it was:
  1. Press the SET button.
  2. After the time blinks, press the REV or FWD button to adjust the time. (Press and hold the REV or FWD button to fast reverse or fast forward time.)
  3. To save settings press the SET button.
  4. Once you have the clock set and have press the SET button, the time should be done blinking.
Give this a try and hopefully it works, good luck
Nov 07, 2008 | Audio Players & Recorders
Setting the time
turn clock on
Press the SET buttom (red Clock icon will come on)
Use fast fwrd / fast Revs button to move clock forward or back
Press the set button when done
Mar 10, 2008 | GE Spacemaker 75300 Shelf System
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
