Question about Panasonic SC-BT100 Theater System
PANASONIC BLUE RAY SA-BT100
THE AUDIO ITS OK BUT WE HAVE VISUAL PROBLEM..I CHECK THE WIRES ITS OK..I CHECK OTHER DVD SAME STILY AND ITS WORKING.
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Cheers,
solutiondoct
Posted on Nov 06, 2008
  • 151 Answers
SOURCE: connection problems
Yes you can by connecting a optical cable from bd35 to your systems optical in put,then select this in put on your sysyem and set sound to prologic2, you will not get HD MASTER or DOLBY TRUE HD audio but will get dolby digital and dts.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
  • 133 Answers
SOURCE: panasonic BT100 & sh-fx67 kit surround sound not working
make sure you have speakers A and B on, sometimes that is the problem
Posted on Jan 11, 2009
SOURCE: I have the Panasonic SC-BT100
Cooling fan is probably dirty or not running. Check the fan by removing it with the two screws on the back and make certain that it's plugged in and the short, black wire (that appears to go to nothing) is "securing" the plug to the board.
Posted on Apr 14, 2009
smarthome2
  • 1114 Answers
SOURCE: CD/DVD PROBLEM ON A PANASONIC SA-HT680
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
Posted on May 22, 2009
How to connect a blue ray player with the sc pt760 sound system with dvd?
According to the models you provided it looks like the DVD player has only HDMI out and the sound system you have does not directly support that. I would suggest purchasing a HDMI audio extractor so that you can covert the digital signal from your blu-ray to an analog signal. However, there are other ways of doing this. If you provide me with your TV that you use I might be able to advise another work around.
Go on google and look for "hdmi audio converter" or "hdmi audio Extractor".
Make sure to look at review to determine the quality of the product and decide what device fits your budget.
Nov 23, 2015 | Panasonic...
I have a panasonic home theatre system Model No SA-HT690 and want to bypass the DVD player and hook it up directly to my new Samsung TV. I want to be able use the surround sound when watching TV and u
you want to instead pass the audio from the blueray
either direct to the sa-hr690 via one of its aux inputs
or via the TV
via the TV makes sense
so find an audio out from the tv
some only have headphones
some a pair of phono plugs
so youll prob need phono to phono cables
and then your good too go
Dec 07, 2014 | Samsung Audio Players & Recorders
How do I mute sound so as I can listen to Blue Ray through headphones
Usually, you should connecct your headphones to your TV, which will mute the internal speakers.
Sep 17, 2014 | Panasonic Sa-bt230 Blu-ray Disc Receiver
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
My sa-bt100 doesn't send audio trhugh the hdmi. I want to hear it through the TV not the external speakers. How do I configure it? Thanks
What TV audio is available to the SC-BT100 that a) isn't available to the TV directly; and b) would sound better on the TV?
I'd look on my cable box for the basic analog audio out and send it to the TV for those times you just want to watch the news without hi-fi. I'd also send the best Video (HDMI) directly to the TV because passing it through the receiver just adds cabling and opportunity for malfunction.
The best audio should go directly to the Panasonic. Period.
Look around fixya for the most common video problems - not passing through the receiver unscathed.
Feb 23, 2011 | Panasonic SC-BT100 Theater System
I have a blue ray Prayer connected to my Panasonic SA-HE100 via a toslink digital audio cable. I don't get 5.1 surround sound. I do get stereo but not 5.1 where the back speakers sound. Any...
hi,
do one thing
1. press and hold DIGITAL INPUT button on the remote( will display AUTO--PCM FIX--DTS FIX)
2. select AUTO among them. and the try
ok
Jan 31, 2011 | Panasonic SA-HE100 Receiver
DMR-E55
Should do.. after all it is only going to record signals OUT from the TV to the DVD recorder IN... as long as it is wired up OK it should be OK. Wire either Component, R,G, B or Audio Visual, .R, W, Y.
Feb 03, 2010 | Panasonic DMR-E55 DVD Recorder
I have the Panasonic SC-BT100 Blue-Ray Disc Home Theater Sound System, and whenever we watch a dvd it plays fine and after a while the tv turns blue but the sound goes off.. after a while it will come back...
Jan 03, 2009 | Panasonic SC-BT100 Theater System
Panasonic SC-BT100 Theater System Logo
57 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
