Question about Sony CDX-L480X CD Player
Front panel buttons don't work
Cleaned the gold-plated connector, which didn't make a difference. Opened up the front panel expecting to see some flimsy broken plastic parts, but actually they switches in there look like decent quality mini-switches and nothing seems to be wrong with it visually.
What will fix this?
    Sniper:
  • 79 Answers
Try some of that really good electronic spray contact cleaner. Did you accidentally spill something on it or it got wet somehow? Please rate me
Posted on Jun 18, 2009
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Preliminary Procedure
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
My start button doesn't work, very loose, appears to be off track to engage
Had same problem but solution was different. Start button looked slightly misaligned and wouldn't always work. Followed instructions to pull off front control panel, removed LED display panel and the plastic tab that the start button was attached to had broken off from the panel. Used a good epoxy to glue the edges back together and it works like new. Also broke two tabs that hold the LED panel inside the front plate due to the plastic becoming brittle. Again, epoxy is your friend. Works like new. d04211d8-3b3d-44fc-bc8c-6da6cd6ecf7e.jpg
Jul 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Ford fairlane1992 electric windows - front driver side not working
Ok Could be one of 3 things...... 1. Bad switch. they're realively easy to replace. Cardone/HELP makes these switches and you can get them at any auto parts store.
2. Bad ground to the window motor.
3. Bad window motor.My best advise is goes the easiest, cheapest route. Replace the swithch first. That way if it solves the problem, you only have a couple of bucks into the repair, and you didn't change anything you really didn't need to get into. If it doesn't fix it, you still have a few bucks into it and a brad new switch in it that you don't have to worry about for a long while.
IF you are not mechanically inclined with automotive elctrical systems, and the switch replacement didn't work, take to a reliable mechanic and have it checked for the bad ground first. Window motors can be pricey.
Oct 10, 2012 | Ford Fairlane Cars & Trucks
How to activate the front panel 3.5 mm jack ??
Usually by plugging into that jack, the computer will notice you have done so. In some computers built by computer engineers after the failure of a motherboard or installation into a new case, the front panel audio connector is not installed so the front panel speaker and microphone connectors don't work.
You can see if your computer detects your front panel connections from Control Panel and clicking on Sound.
Jul 24, 2011 | Computers & Internet
I have just had sky HD box installed but need a DVI to HDMI converter, however i cannot locate a one that fits my philips 42pf7520d tv.
I would expect most shops to carry that connector Here some links - I would expect Maplin to have a cable - however, I cant find a image on there website - so heres some links to amazon, I used the online manual - let me know whats different about these DVI connections on the TV - look the same from the manual
  • http://www.amazon.co.uk/Labgear-Premium-Gold-Plated-Adaptor/dp/B000GHQO0C
  • http://www.amazon.co.uk/Premium-HDMI-Cable-Gold-Metre/dp/B000GDI6FC/ref=pd_cp_ce_2
heres the support site for that TV http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7520D/10&slg=en&scy=GB
Direct link to user manual http://download.p4c.philips.com/files/4/42pf7520d_10/42pf7520d_10_dfu_eng.pdf
Apr 07, 2010 | Philips Televison & Video
Hi Can any advise how i add a new belt to a hotpoint 9324 dryer ? Is it from the from or rear & if possible the configeration how the belt goes around the pulleys at the bottom. Thanks Graeme
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly.
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Sep 10, 2009 | Hotpoint Dryers
Buttons don't work. Sometimes when I click Source button several times, radio gets turned on if I have enough luck, but in most cases it's pointless), then I can change nothing. Volume change, programm...
Try resetting it. Remove front panel, on main unit is an indent that says reset, insert ballpoint to reset and replace front panel. Everything should now work although you will need to reset stations and clock.
Apr 18, 2009 | Sony CDX-L480X CD Player
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
Lights
fuse or connector in rear boot ,if fron side light works its the connector if side light on front doesnt work its a fuse
Aug 10, 2008 | 2001 Ford Focus
Can't get the front panel off
remove the back bottom screws that are inside ,and pull out the control panel it has magnetic holders
Jun 19, 2007 | Sony KDF-50E2000 50" HDTV
Sony CDX-L480X CD Player Logo
95 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
