Question about Lincoln 1242 Cordless Grease Gun Kit
Pump no grease out - Lincoln 1242 Cordless Grease Gun Kit
Lincoln model 82050 grease pump doesnt shut off
The valve that controls the grease or the valve that controls the air(?).. one is stuck.. the air valve can stick and cause too much PSI and the grease valve cannot overcome the pressure to allow it to close.
Sep 07, 2017 | Lincoln Air Tools & Compressors
How many grease ******* on a 2009 flstf and where are they located.
grease should be administered sparingly
one pump of the grease gun every 1 month
excessive grease beside splattering over everything will in most instances cause overheating especially in spinning bearings
Mar 29, 2017 | Cars & Trucks
What is the purpose of this nipple on the pump does it need anything attached to it
A nipple usually is a grease or oil point - you pump grease or oil in with a grease/oil gun.
The other use of a nipple is as a bleed point - think of your brakes. There's a bleed point - nipple - that you open whilst pumping the brakes to remove air from the system.
Jun 28, 2016 | Cars & Trucks
When greasing drive shaft how many pumps with grease gun?
Pump the grease until you see a small amount coming past the seal.
Should only take about 1 to 3 pumps but if dry may take 5 pumps.
May 10, 2015 | Cars & Trucks
For what Purpose Alemite Grease Pump is used?
The main function of Alemite Grease Pump is it reduces friction and increases the productivity. Alemite grease pump does is that it pumps a certain amount of grease into the perfect places where friction is produced because of the movement of machineries and its components; this particular pump not only pushes the right amount of grease, but also makes it show to push the grease at the right time.
Article source : http://www.fdjohnson.com/
Aug 21, 2014 | Lincoln Automotive Air Operated Grease...
How do grease pumps help in reducing friction ?
Alemite grease pump function is used to pump a certain amount of grease into the perfect places where friction is produced because of the movement of machineries and its components; this particular pump not only pushes the right amount of grease, but also makes it enough capable to push the grease at the right time. Article source
Jul 19, 2014 | Lincoln Lubrication 1293 Hand Operated...
How do i service the grease trap without calling a service man to do it?
Be clear that an in-ground grease interceptor cannot be cleaned without a grease trap pumping company. We are referring to a metal grease trap that sits under the 3-compartment sink. Yes it can be cleaned by anyone (crazy enough). I still suggest a professional service company perform the task. I have full directions or instructions now at www.greasetrap.ca/grease-trap-cleaning.htm . Old clothes and a mask are a must.
Grease Trap Cleaning
Sep 20, 2010 | Dishwashers
When I reload the Greasegun, it won't pump grease! Doesn't matter if it is an Air Operated Greasegun or a Pump Style! What is the secret to getting out the Air Pockets??????
might try and bleed it like brakes.... take the hose off and put your finger over the hole. pump until you only get grease... just a thought, there is a valve in the end of the hose for clamping onto the zerk fitting... mightnot be enough pressure building up to let the air run through...
Just a thought....
Mar 02, 2010 | Lincoln Air Operated Grease Gun
Is there a specific type of grease gun ad grease I
There is really no special grease gun to get. Any type of grease gun will work. I personally use a high temp. grease at the shop I work at. When greasing anything never over grease a joint , it causes a mess and will cause premature failure. All that is needed is three pumps of the grease gun.
Aug 16, 2009 | 1993 Lincoln Town Car
Lincoln 1242 Cordless Grease Gun Kit Logo
26 people viewed this question
Top Lincoln Air Tools & Compressors Experts
Steve P
Steve P
Bill Boyd
Are you a Lincoln Air Tool and Compressor Expert? Answer questions, earn points and help others
