Question about HP LaserJet P3005n Printer
Dirty pages when I print, the page comes through with a dark dirty area on the page, anyway I can clean something to stop this
    Sniper:
  • 79 Answers
Try to see if there may be trash or dust in were the ribbon/cartridge goes. Take it out and make sure. Look thoroughly for anything out of place. You may have to change it. How long have you had it. Pleas rate me
Posted on Jun 18, 2009
Light wide strips printing on page.
have u checked the itb, image transfer belt.
or transfer roller
Sep 17, 2015 | Samsung CLP315 Color Laser Printer
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
Printer problem for a dell 924 printer
I have run across several Dell & Lexmark printers that after a while of working great, decide to have an "issue"... If you are printing more than 1 page, they will print the first page, then stop. The computer says "Cartridge Stall" and the printer says "Hardware Error 0502" or something similar, depending on the printer... Anyway, the message on the computer suggests making sure your cartridges are installed correctly, and nothing is blocking their path... After dealing with this many times, I have finally found a solution that seems to work!
There is usually a metal bar that the cartridges slide back and forth on... over time, this bar can become "gunked up"... Use alcohol pads to clean up the bar, and the surrounding area.... Clean out as much of the track as you can also. Tada... .No more cartridge stall!!
Oct 22, 2009 | Dell A940 All-In-One InkJet Printer
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
The mechanism that takes paper from the tray to the printing area feeds several pages at once so i get printed page, blank page, blank page, printed page, blank page, blank page etc
I am not sure of the printer that you have, but it could be that the seperator pad is dirty or the paper feed rollers are dirty. You can clean them with a little isopropyl alcohol and a soft cloth, Make sure the printer is off when doing this procedure.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 19, 2009 | Office Equipment & Supplies
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Jun 04, 2009 | Lexmark E232 Laser Printer
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Dirty Cartriage or Printer head
you should clean the printer head or cartriage
Aug 31, 2007 | Lexmark Z715 InkJet Printer
HP LaserJet P3005n Printer Logo
210 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
