Question about Frigidaire Grindpro 3/4-HP Garbage Disposal with Sound Insulation FPDI
Grindpro is stuck
Only make noise when turning on but is stuck
  • Frigidaire Master
  • 5,245 Answers
I need help on food disposer
The motor is stuck. Use the allen wrench that came with unit and insert into spot under neath the unit and see if you can unstick it.
If not successful unit needs to be replaced since it is frozen solid and will not turn nor grind.
Aug 31, 2015 | Garbage Disposals
How do you repair a garbage disposal?
Depends on the problem.
Odor, noise, clog, leaking, stuck, reset, installation, etc...
Following link has resources for most general problems:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 25, 2015 | Garbage Disposals
How do i repair gec disosal unit
Most Disposals are not worth repairing. If the motor won't work, try pushing the rest button on the bottom of the unit. If it won't turn, use an allen wrench to manually turn the impeller and see if something is stuck. You can also use a broom handle to turn the impeller.
Jan 05, 2015 | Garbage Disposals
How to fix a stuffed garbage disposal?
It should have come with a Allen wrench. Be sure it is off. Insert it in the bottom into the center hole. Move it back and forth several times until it frees up. Remove wrench and try, you may have to do this several times. Also be sure the unit is reset before turning on. If it does nothing nor makes nay noise it is probably tripped.
Aug 08, 2014 | In-Sink-Erator Evolution Pro Cover Control...
Reset button not working
Try reset button on bottom of disposal.
Following link has full troubleshoot resources:
If reset will not restore functionality, check that unit is getting power, and then check that unit is receiving 80% rated voltage. Replace disposal.
Add a comment
Jun 20, 2013 | Whirlaway Garbage Disposals
Replace garbage disposal shredder disc
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
Add a comment and say where you are getting the parts and which model
May 25, 2013 | Kenmore 3/4 hp Food Waste Disposer
Garbage disposal runs but will not take garbage down
can you turn it on for me? I would like to see and hear whats going on to better help diagnose, more than likely the "blade" that spins has detached from the disposal motor assembly or the "blade" my be caught/stuck in place, to resolve this issue.
Unplug the disposal(should be plugged in under the sink)Grab a bucket to place under sink to catch waterremove the sink pipe assembly+disposal (remove the disposal)the water should drain into the bucket from the sink.remove and clean the disposal trap, looking for obstructions while you do so.after cleaning and searching for obstruction, reassemble the unit as it was making sure to reinstall all washers, guards and bolts, after you reassemble the unit plug it back in and test it, if you get the same results then there may be a strong possibility the unit suffers from a defect or damage in which case you may need to replace the whole unit or just part it all depends... good luck... more question just ask
Mar 29, 2013 | Garbage Disposals
Garbage disposal
make sure that the fuse is not blown, make sure there is no fork/spoon/etc stuck in the disposer. if it still doesn't work, you have to provide more information about what happens
Mar 29, 2013 | Waste King Whirlaway 291 1/2 Horsepower...
Frigidaire Grindpro 3/4-HP Garbage Disposal with Sound Insulation FPDI Logo
494 people viewed this question
Top Frigidaire Garbage Disposals Experts
Gene Haynes
Gil Shultz
ray gallant
Are you a Frigidaire Garbage Disposal Expert? Answer questions, earn points and help others
