Question about Pioneer DEH-P9600MP CD Player
THE SECOND DISPLAY SCREEN STOPPED WORKING
THE SECOND DISPLAY SCREEN ON MY IN DASH CAR STEREO STOPPED WORKING SO NOW I CANT CHANGE MY SOUND SETTINGS OR SEE THE ANIMATIONS THAT IT DOES
    Problem Solver:
  • 6 Answers
I have the same deck. replace the flex ribbon to sub panel. It's a problem with this deck. I've replaced the rear panel ribbon numerous times as well as the front panel ribbon.
Posted on Jun 30, 2009
    Sniper:
  • 79 Answers
Did you accidentally spill something on it? Is the face detachable? Please rate me
Posted on Jun 18, 2009
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
Just bought 2002 Saturn L100 owner said radio worked before they took battery out to charge it. Now all the lights work but the sound wont come out. Help
Sounds like you need to input the radio code . i would look in the glove box for the code either on a sticker or a card or ask them if they know about the code .
Instructions
Deactivate Theft-Deterrent Feature
  • 1
    Place the key in the ignition and switch it to the "RUN" setting.
  • 2
    Press the volume control knob in to turn the stereo off, if it is not already off.
  • 3
    Press the number "5" and "6" button on the radio simultaneously for approximately five seconds until four dashes ("- - - -") appear on the display screen. You must then enter the four-digit unlock code that you originally assigned to your vehicle. If you are unsure of the unlock code, contact your local GM retailer.
  • 4
    Press "SEEK/SCAN" upward to set the first number.
  • 5
    Press "SEEK/SCAN" downward to set the second number.
  • 6
    Press "TUNE" upward to set the third number.
  • 7
    Press "TUNE" downward to set the fourth number.
  • 8
    Verify that the code on the display screen matches your stereo unlock code, then press the AM FM button. You will see "REP" will display on the screen. Enter your code a second time for confirmation. "OFF" will appear on the screen, confirming you successfully deactivated the theft-deterrent feature.
Nov 05, 2013 | Scosche Industries 08-up Saturn Astra...
Stereo stops dash display working
It sounds as though your stereo may be improperly wired, or perhaps there is a blown fuse or exposed wire causing a short. I would suggest checking the wiring diagram for your vehicle/stereo, or taking it to car audio store/ whomever installed the unit, and having a technician examine it. I hope this helps =)
Jul 10, 2013 | JVC AM FM CD DET FACE CAR STEREO
Most stereo functions just stopped working.
Sounds like you have an internal short in the stereo. Or could be that the face of your stereo is worn out too. Get another radio.
Feb 12, 2018 | 2005 Dodge Durango
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
I am istalling a jvc car stereo in my 92 chevy truck. The stereo wire connections have been cut. I was able to find the car stereo wiring schematic online. My problem is: when i turn the key to accesory...
hi this sounds like you have connected the permanent live wire to an auxiliary wire, ie, what ever the power source you have connected it to, only works until the vehicle has started, then the power is stopped, sorta like.. say, the starter motor, it only uses the power when it is needed then when it is running it shuts the power off, just like the lights on the dash ect ect, your best bet would be to find a permanent live from the battery supply...hope this helps
Jul 14, 2010 | Car Audio & Video
No sound from 2004 Audi A4 factory stereo
You just go to the link I attached I'm sure you will get the solution of your problem
2004 Audi A4 Workshop Repair Service Manual PDF Download
Sep 06, 2017 | 2004 Audi A4
CDA-9855R - Sound setting constantly changes
It's possible the stereo is in some sort of "demo" mode. To verify this setting, go to Menu-->Demo and set it to "Off".
Feb 18, 2008 | Alpine CDA-9855 CD Player
Pioneer DEH-P9600MP CD Player Logo
428 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
