Question about Samsung SC-D353 Mini DV Digital Camcorder
Tape keeps getting spit out - Samsung SC-D353 Mini DV Digital Camcorder
I bought the vcr quasar vhq 940 used and it keeps spitting the tape back out. How do I fix it?
It means the unit has either a bad belt or belts or a bad drive wheel--if the tape goes in the unit opens the cassette and feeds the tape out--if broken or loose belt it will not make it fully out against the video heads and will spit tape out.
Used to be by model number belt packs with a idler included to replace all at one time.
Use or hours does not matter as if the unit sits a long time or is rarely used the belts and idler (rubber) will degrade and cause problems.
Apr 10, 2012 | Televison & Video
E 10 tape deck error/ tapes keep spitting out
The radio checks to make sure the drive capstan is turning - if not, gives the E10 error. Either the drive belt in the radio is slipping or the drive wheel in the adapter is sticking. If it does it with a real cassette, then it's probably the drive belt. If not, you can try to figure out why the wheel in the adapter is not turning freely.
Jun 21, 2017 | 2001 Oldsmobile Intrigue
I've paid for your service but have still not received an answer. (invoice #268236) I have a sylvania 6720FDF 20" TV (triple combo). the vcr won't work. when i put in a tape it'll immediately spit...
there are a number of things that can cause this.
If there's something as simple as a penny underneath the tape loading area (anywhere the tape sits when fully loaded) the sensor that tells the vcr that the tape is fully down won't register, and the unit will spit the tape back out.
there is an optical sensor that goes into a hole that you can see on the bottom of any tape, and if either the emitter (the light bulb) or the detector (which detects the light from the emitter) isn't functional, it'll think the mechanism loaded without a tape in it, and will spit it out.
If the loading mechanism for any other reason doesn't go all the way down, if the unit is unable to spin the heads or if the mechanism that winds the tape around the head can't move, it'll spit out the tape.
This by the way is a free answer, if you paid for an answer and didn't get one, ask for a refund, we do have a refund policy.
if you paid for a year or something like that, I don't know how that works, but I hope I have helped you.
If you are still stuck after checking all the things I mentioned, please post a reply to this post and I will try to assist you further.
Mar 20, 2011 | Televison & Video
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
Dlt-v4, the drive accepts the tape only to spit it out
You have to try the other tape if the same problem you have to replace the head.
Feb 05, 2010 | Quantum DLT-V4 DLT Tape Drive
Tape deck spitting tape out
Time for a new car stereo. I recommend something that you can plug a flash drive into that will provide hours of listening pleasure. Repairing the factory tape deck is not going to be economical. Since the stereo has to be removed to diagnose it, much less repair it, just fill the hole with something else. If you absolutely love the factory deck, salvage yards everywhere have them available for less than the cost of a repair.
Jul 06, 2017 | Car Audio & Video
Keeps spitting out tape, and shutting off
mode switch needs cleaned under tape unit on ckt board.. pain to get to. Put it together, pointing the same way when you took it apart looks like a round dot the size of a penny, with a shaft sticking up on the top twards the back
Mar 16, 2009 | Sylvania ZV450SL8
Wont accept cleaning tape
Make sure there are no pending jobs on the drive, if the drive is expecting a tape and gets a cleaning tape it will spit it out. Also, has the cleaning tape been used a lot? They have a limited life cycle and if they have exceeded their max uses they may not work.
Nov 13, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Dell Dat 72
try a different Cleaner tape, they dont last forever..
Jul 24, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Camcorder keeps spitting the tape out when I put one in
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100. Of course mine is out of warranty. Everyone should call Cannon and complain.
Mar 01, 2007 | Canon ZR100 Mini DV Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
21 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
