Question about Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7
Cannot hear radio broadcast audio
Speakers are on,volume up,can hear selection clicks but no other audio.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 64 Answers
First thing to check is your settings for sound. Go into settings and click on sound . The options are there. Make sure it's not on mute or something similar. Try changing the setting. Next is plug in your earphones in the jack. If that works then your jack is open after you take the jack out. If none of this works then a connection to your internal speaker has come loose or off.
I am not familiar with your unit. Just standard stuff on all tablets is what I am suggesting.
Posted on Apr 14, 2014
  • Peter Apr 14, 2014
Only bought it yesterdsy sound volume up full but cant hear it
Hi Jon, The link below is a youtube web page showing problems and solutions with audio that should help you mate.........CHEERS..
sound volume up full but cant hear it on tablet YouTube
Apr 16, 2016 | Tablets & eReaders
My sound is not loud enough on my rca 9" dual core tablet model"RCT6691W3, and volume is on max
Some devices just suck at audio. I have a Lenovo laptop that does the same. Bad onboard speakers require external speakers to produce suitable sound level.
Feb 22, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
My volume is not working even when I turned on but still nothing happend I powered off then back on but still nothing happened
Now Jennifer, do you mean the sound or the volume controls? I assume you mean the sound. In that case, can you hear anything when you plug in headphones? Is there a little headphone icon displaying on the screen? Can you make the volume bar display and move it up and down?
In Settings > Audio Profiles, you can choose ringtones and such, and set the volume levels of various audio sounds. It will also play a sample of ones you select, which is a quick way to see if the audio works.
You can install the "Z-Device Test" app from the Play Store, and it tests all sorts of things on your android. Maybe it can help.
Sep 26, 2014 | Avatar Android Tablet 7" 2nd Gen Single...
Does the KImble have an output socket so that the audio (talking) feature for books can be used through the car audio system
The Amazon Kindle has a headphone (3.5mm) jack which can be used to listen to audiobooks - a male-male extension cable can extend this to allow the output to be played through another medium, if your car has the same size jack. If not, there are some products which will broadcast the audio on a low-grade radio frequency with roughly the range of your car (for example: http://www.amazon.com/Transmitter-Kindle-car-power-cable/dp/B0020KKWLK), allowing you to listen to your ebook on a particular radio frequency.
Hope this helps!
Mar 26, 2011 | Amazon Kindle 2
Volume not working
You have lost your audio driver. Go to manufacturers web site, help and support center, and download the new driver. That should fix your problem
Nov 15, 2009 | Gateway M280E
TC1100 SOUND PROBLEM
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers
Jun 30, 2009 | Compaq tc1100 Tablet PC
Yurning up volume
I'm going to make an assumption (assume=*** of u & me) that you are dealing with an Intel/Win machine.
If not, forget everything I wrote here.
It's helpful if you mention what your system and OS is.
You will need to click or double click on the speaker symbol on the task bar; if organized as common, it will be on the right.
On Win XP, a single click opens only the voulume control, double click gives you a detailed panel (different audio cards/chips look different since this is a software function) that allows you to control the level of different inputs or file types.
The presence of a speaker symbol on the escape button is kind of puzzling but may be a function of an extended keyboard that requires a manufacturer's device driver to be loaded when you boot.
That may not be loading.
(Some icons may require double clicks-)
If yes, then click on the Start menu, select Control Panel, then Sounds & Audio devices (or similar), this will show you if the sound is muted and let you select default volume level and tell you whose audio is installed.
If it looks OK, close the window and then click on the System icon, then Hardware, finally Device Manager.
Check the list for open folders that involve sound devices for any red 'X' on functions.
If you find one, then something hasn't been installed or turned on and since we don't know the exact system you have, it may require different methods of 'fixing' the problem and then you will need a friendly nerd nearby to help you.
May 27, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Screeching noise
right click on the speaker icon in your taskbar, select Open Volume Control. If you do not see the Microphone control select options>properties and select it from the list of check boxes. Press OK. Check the mute box for your microphone.
Jan 04, 2008 | Lenovo ThinkPad X60 Tablet PC
Audio Not working.
hi. i had the same problem all audio worked just when i pluged earphones in sound was going from speakers not from earphones. well i had before some problems with windows what may cause it. dont know why but after pressing Fn+F5 the earfone output started work corectly. probably some hardware initialization failure
hope it will work for u
Dec 15, 2007 | IBM ThinkPad X41 Tablet PC
Audio feedback
this maybe was cause by a grounded connection.
Please try put a grounding wire from your stuff to the ground. this elimanate noise.
if this not work, do not rate me instead notify me for another solution im online 12 hours day.
Sep 13, 2007 | Acer TravelMate C110 Tablet PC
Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
56 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Lawrence Oravetz
 Grubhead
Grubhead
micky dee
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
