Question about CardStar
Change cardstar password - CardStar
Evelynwms132GMAIL.COM
Change your password on a phone or tablet
  • Go to accounts.google.com/EditPasswd.
  • Type your current password and your new password.
  • Touch Change password.
Change your password on a computer
  • Open Gmail.
  • Click the gear in the top right.
  • Select Settings.
  • Click the Accounts tab at the top.
  • Click Change password in the "Change account settings" section.
  • Click Change password.
Source: https://support.google.com/mail/answer/6567?hl=en
Hope that helps!
Jan 30, 2014 | Computers & Internet
Tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 | Computers & Internet
How do I change my password?
To change your Gmail password on a phone or tablet:
  1. Go to accounts.google.com/EditPasswd.
  2. Type your current password and your new password.
  3. Touch Change password.
To change your Gmail password on a computer:
  1. Open Gmail.
  2. Click the gear in the top right.
  3. Select Settings.
  4. Click the Accounts tab at the top.
  5. Click Change password in the "Change account settings" section.
  6. Type your current password and your new password.
  7. Click Change password
Hope that helps!
Jan 23, 2014 | gmail.com
How to get a new user account password
for xp
Click the "Start" button.
Double-click "User Accounts."
Select the user account you wish to change.
Select "Change My Password." If you wish to remove the password, select "Remove My Password."
Enter the existing password in the first field.
Enter your new password in the second and third fields.
Enter a password hint in the fourth field.
Click "Change Password."
hope this helps
Aug 31, 2012 | Computers & Internet
How do I remove log in username
for which operating system ????
Windows XP users
Change password
  1. Open Control Panel
  2. Double-click the Users Accounts icon
  3. Select the account you wish to change.
  4. Select the option "Change my name" to change your username or "Create a password" or "Change my password" to change your password.
Note: Windows XP Home users can only change the Administrator password through Safe Mode
Windows Vista and 7 users
Change password
  2. Click Add or remove user accounts.
  3. Click the account you wish to change.
  4. Click Change the password
Change username
  4. Click Change the account name
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
  2. Double-click the Users and Password icon
  3. Make sure "Users must enter a user and password to use this computer" is checked.
  4. Highlight the account you wish to change the username for and click the Properties button.
  5. Within the Properties you'll be able to change the User name.
hope this helps
Sep 25, 2011 | Computers & Internet
Kos change password
k.o.schange password
Apr 23, 2011 | Dryers
I trying to change my pass word to my computer.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
Feb 03, 2011 | Computers & Internet
How can i change my password ?
hope this helps
Jan 26, 2011 | Computers & Internet
CardStar Logo
141 people viewed this question
Top CardStar Apps Experts
Erin Wood
Erin Wood
Are you a CardStar App Expert? Answer questions, earn points and help others
