Question about Zenith R57W46 57" Rear Projection Television
Remote will not make it turn off or select inputs
This is an R57W47 CA. I am assuming the same manual works. The lady I bought it from lost the remote. The On/Off push button has been punched in and is possibly stuck. I have tried a universal remote from BestBuy, A DirecTv universal remote and purchased an LG remote that is supposed to be the proper replacement. None will program to turn the TV off much less change the source from CATV. How do I get the case open to clean the boards and repair the ON/OFF switch?
  • 196 Answers
SOURCE: Menu, select buttons not working
Try getting a universal remote that would let you get into the menu and change the settings you are thrying to change.
Posted on Feb 09, 2006
SOURCE: zenith e44w46lcd Volume stuck at 100 and won't go down
replaced the main board.
Posted on Feb 19, 2008
SOURCE: Sentry really big universal remote
Request Information by sooky, posted on Jan 12, 2008 Does anyone know the codes for a Vizio LCD TV?
The code to use is LG 1292...these other two have worked for others as well...0178 or 0030. good luck
Posted on Apr 14, 2008
SOURCE: TV does not respond to the remote control
I had this happen on mine after about 3 years. Luckily it was on extended warranty. At first the techs re-soldered the connections to the board for the IR sensor but the problem was still intermittent. The next time they replaced the mainboard and all is well - just like new.
Posted on May 26, 2008
SOURCE: very poor resolution
go to ebay and you can get the zenith remote for that tv for 20.00 dollars because i got a new one from ebay
Posted on Jun 20, 2008
Lost combination for model MSW 3617
I BOUGHT IT FROM A LADY AND SHE FORGOT THE COMBINATION TO OPEN IT... IT IS OPEN AND LOCKED OPEN...HOW CAN I PROGRAM A NEW COMBINATION FOR IT?
Apr 15, 2013 | Sentry Safe Fire-Safe Personal Safe
Venza remote keyless entry problems
I have the 2010 Toyota Venza push to start. I lost the original key, so i bought a new key with the remote and its was programmed successful but this remote only had the three buttons on it, instead of four buttons ( Including the Hutch button). So i bought another new remote with the four buttons today and I want to know if it will work when i switch the programmed key into the new remote?
Feb 04, 2012 | Toyota Venza Cars & Trucks
Just bought one of these used and need to adjust the color brightness contrast etc. I assume I do this thru the "menu" option. I don't have the original remote with the unit and I can't get any universal...
Try website like Remotes.com to buy the original remote it ur best bet.Tries the manual control on the tv.Push the Menu button use the channel + - and the volume + - on the manual buttons to adjust colors,contrast,brightness.
Jul 04, 2010 | GE 13TVR62 Combo
Lost a tv remote in a fire. Bought a universal remote but cannot fine a code to program it.
read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
Dec 18, 2009 | Vizio L32 32 in. LCD HDTV
Car remote not working
Sounds like you need a remote, or the remote lost its program. You need to check at the dealership to be sure.
Aug 28, 2009 | 2002 Pontiac Grand Am
The power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Mar 27, 2009 | Sharp 27N-S100 27" TV
Control
Try dropping it again. Seriously. Inside the remote there is a very small 'gyro sensor' that can get stuck in one spot, basically all you have to do is jar it loose again.
I actually had this same thing happen a while ago, I called Nintendo customer support.
I was surprised. A very pleasant lady took my call within one minute of getting through the push-button maze to get to Wii Remote troubleshooting.
I explained what the problem was and what I had tried. She then asked me to check one more thing - the Wii Sensor - which checked out. Then the conversation went something like this:
Friendly Nintendo Help Desk Lady: "Okay - I want you to take the remote, button side down and smack it into the palm of your hand two or three times."
Me: "You've got to be kidding"
Friendly Nintendo Help Desk Lady: "No sir, do it hard enough that I can hear it across the phone line but not hard enough to damage the remote"
Me: "You're sure?"
Friendly Nintendo Help Desk Lady: "Yes, sir."
So, button-side down, the funky Wii remote got smacked in the palm of my hand three times....
...and the thing worked!
Nov 06, 2008 | Nintendo Wii Console
Codes for Universal remote for a Durabrand speaker system
You will need the manual. Probably have to hold Menu or a combination of buttons for a couple seconds and punch in the appropriate code for your device. You can find just about any manual online...just google everything you know about the remote and look for a manual pdf or something. Good luck!
Dec 24, 2007 | Durabrand HT-3915 System
Combination TV/VCR will not work from original remote.
try stripping your old remote and cleaning it, i find cleaning the contacts on the pcb and the buttons themselves with aftershave is the best
Feb 26, 2007 | Quasar VV-1311W 13 in. Combo
Zenith R57W46 57" Rear Projection Television Logo
26 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
