Question about Cell Phones
Imac freezes up
I have iMac computer made in 2008.RAM 2GB.Recently it frequently freezes up (beach ball appears and no matter how long I wait it does not go away) Disk Utility does not indicate any problems .Considering this and the fact that I do not hear any clicks,noises etc makes the impending failure of HD unlikely.The only way to deal with the problem is to switch off the computer using a power button.Switching to another browser does not help.It can happen regardless of what I am doing eg accessing a webpage reading email)When these problems occur there is usually approx 50% of fre memmory and a lot of free space on HD.I did not recently install any new sofrware My operating system is OX 10.8.6
  • 42 Answers
This sounds like overheating.. if the fan on your processor has failed you will get some time when you can use the pc and then it stops. Turning off for 15 minutes and then back on again gives you a little more time.
Solution.. check cooling fins are clear of dust and the fan is running freely, lack of cool airflow is the usual cause. if there is no dust and the fan is running then it is possible that the processor is suffering from failing ram.. try replacing your ram..
good luck.
Posted on Mar 30, 2017
jayjaybeebee
  • 9 Answers
SOURCE: Nokia 6233: Problem with memory card
see what the phone properties sees the memory card space as.
Posted on Jul 25, 2007
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Posted on Aug 07, 2008
  • 477 Answers
SOURCE: C: Drive space issue
Hello
if you have to little space on your C partition you can resize it, if you using vista.
1. right click on my computer->manage
2. choose storage->disk management
3. right click on the C volume and extend volume
4. put more space on C and then OK. that should solv your problem
you can also move your swap file to D: that gonna save some space on C.
1. rightclick on computer ->properties
2. click advanced system settings
3. click on the advanced tab settings on performance.
4. choose advanced tab->change
5. click on D: and write a custom size(it should be double of your amount of ram)
6. click set
7. then click C in same window and choose "no paging file"
8. click set and ok, then restart your computer.
good luck dont forget to vote.
Posted on Sep 08, 2008
  • 58 Answers
SOURCE: System getting disk boot failure r disk error report
It could be a problem with your hard drive. It's starting to fail, may be some day you cant boot anymore. Try replacing it!
Posted on Jan 22, 2009
SOURCE: micro sd 4gb micro card.
Guaranteed solution!
This is from Duracell Support
Unfortunately, we have found an incompatibility with a new revision of our microSD and the USB adapter that accompanied the card you purchased. We are in the process of solving the compatibility issue. We are truly sorry for the inconvenience and would like to send a new card that is compatible with your USB adapter. Your original card should be functional in other adapters, phones, and cameras. The microSD card's compatibility problem should only exist with that USB Adapter. For your inconvenience, there will be no need to ship the original microSD card back to us so feel free to keep and use them both. We would also like to send you two free music downloads from Duracell Flash Memory.
If you would like to take advantage of this offer, please let us know your full name, address, the size of the microSD, and the name and location of the store from which you purchased your microSD. When we receive your information we will ship your replacements parts and music downloads immediately.
Best Regards,
Duracell Flash Support Team
Here is how to reach them:
http://support.duracellflash.com/ics/support/default.asp?deptID=5612&ticketID=7688933
Posted on Jan 29, 2009
Fix ya com
It could be "bad RAM" -- run a RAM-testing program, or remove the RAM and install different RAM.
Like trying to use chalk to write on a chalk-board that has a few "greasy" spots, and being unable to read what you wrote, having bad RAM causes the computer to "freeze" when it cannot read from the RAM.
Apr 13, 2014 | Cell Phones
Fix ya com
When you say you've used Disk Utility, have you done both Repair Permissions, and Repair Disk? For Repair Disk you need t boot from a different drive, the original install DVD if you have it?
Another thing to try is, remove and and then replace the RAM chips, sometimes the connections need to be re-seated.
Thanks,
John
Apr 13, 2014 | Apple iMac Computers & Internet
STAC2000106 freezes
forst check the usb cable, if it is loose replace it, if not then may be a board problem
Aug 18, 2013 | Seagate FreeAgent GoFlex Desk STAC2000106...
I would like to know if an older hard drive from imac model A1076 could be installed in a slightly newer imac, model A1145 and have it be compatible and working with no problems?
Hard drives are universal, and based on physical connection / type. So your older HD should work even if you have newer SATA connection. The connection is backwards compatible.
Dec 08, 2012 | Apple Imac G5 20" Als G5 2.0ghz 2gb-ram...
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Imac i3 with 8 gb ram is still too slow
Well, there are a lot of reasons that can consequently cause the issues on your iMac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up tool as it can help resolve all issues in just a few clicks.
Nov 22, 2011 | Apple 21.5" iMac Desktop
My 24" Aluminium iMac (early 2008 model) with 2.88Ghz 320g hard drive and 4g rams would freeze out of nowhere...I have ran various program tools to scan (tinkertool, DiskWarrior etc) soft and hard ware but...
Thank you for contacting Fixya Support, I am glad to assist.
In cases where you are experiencing issues with your iMac 24" and you have already tried hard drive and software repairs (including Tinkertool and Disk Warrior), one troubleshooting step I would recommend you try is unseating and re-seating your RAM card one module at a time.
Once you have tried this, then run Disk Warrior, run the Repair Disk Permissions (at least twice).
Once you have run the Disk Repair option, then perform a Disk Rebuild (it will not remove your files from your hard drive but actually rebuilds the Mac OS X directory) and reboot your iMac.
Try this procedure and see if that makes a difference in your iMac's performance.
Let me know if this helps.
Regards,
-Mactechtrainer
Sep 03, 2010 | Apple iMac 24" Desktop
Spinning wheel of death (beach ball)
Open the Activity Monitor application can see what process is taking the most CPU time.
You can also use the "top" utility by opening the Terminal program and then typing "top" and pressing return at the command prompt. To quit top just press the "q" key.
Mar 05, 2017 | Apple Computers & Internet
Imac freezing
Few Questions answered can help me out.
1)Did you update the OS
2)Did you install any drivers recently
3)did you install any software's
4)is any external devices connected when facing this problem
5)did you put new RAM inside
6)did you try to boot from the DVD disk 1 and repair hard drive using Disk utility
This can easily help to resolve the problem
Dec 02, 2008 | Apple iMac 24" Desktop
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
