Question about Dimplex Heating & Cooling
Dimplex zamora electric fire
No power to fire, changed fuse in plug but still not working
SOURCE: I have a dimplex flame effect fire which has just
Solved it! Put it in the dustbin.
Posted on Oct 19, 2009
SOURCE: dimplex opti-myst fire main effect bulbs not
i've got the same problem - have you fixed it yet??
Posted on Jan 01, 2011
  • 4736 Answers
SOURCE: Just purchased a dimplex DS5629
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Posted on Apr 01, 2011
  • 4736 Answers
SOURCE: Where can I get replacement stones for Palermo
The model you listed is only sold in Europe. However, if you live in or near the UK, you purchase the stones from Fires and Fireplaces Direct 085-239-0034 http://www.firesandfireplacesdirect.co.uk/cat-electric-fires.php
Hope this helped you find your stones.
Posted on Apr 07, 2011
Testimonial: "Thanks for that info, I'll be contacting them later. Good stuff 5*"
  • 4736 Answers
SOURCE: I need to change the
The plastic ember bed lifts out with a little effort. To assist you, I have included a link to your Bradford model Owners manual that you can download and print for future reference.
http://www.dimplex.com/customer_support/technical_and_troubleshooting?docsearch=GDS26-BW1052&type=&dlang=
Dave, I hope this helps you.
Posted on Apr 29, 2011
Dimplex cheriton fire model CHT20LE wont turn on
Check the fuse isn't blown in the plug. If it is not, then you would unfortunately need to open up the fire and check the internal wiring and connections, check the switches with a multimeter to make sure they are working. There really isn't much inside these units to go wrong! So any fault should be rather easy to find
Aug 02, 2013 | Dimplex Heating & Cooling
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
Went to switch on fire switch blew up i have changed fuse in plug thats all ok so i think the triple switch is blown .
To purchase a new 3-way rocker switch, contact Dimplex Tech Service 1-888-346-7539.
Hope this helps and thanks for choosing FixYa.
Sep 22, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
How do I change the bulb in my dimplex wynford inset fire?
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Dimplex DS5603 Heater
I need to change the bulb in a dimplex brayford electric fire, how do I get the fake coal plastic off.
Apr 29, 2011 | Dimplex Compact Electric Flame Stove...
Motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Feb 02, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Heating & Cooling Logo
11 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
