Question about Goodman Heating & Cooling
Unit blows cold then it stops blowing then it blows again for a bit and stops and it doesnt seem to be blowing nearly as hard as it should.i just spent about 6 hrs making sure all the duct work and return was nnot collapsed or clogged and vaccuumed out the return coil . not sure if it needs something like freeon or something or what to do next?
    Genius:
  • Goodman Master
  • 1,363 Answers
Sounds like fan motor issue. capacitor or motor bad with reduced air flow coil will freeze up
Posted on Aug 14, 2015
  • 85 Answers
SOURCE: Heat Pump Stops Working only in the Early Morning
I recommend getting electric back up heat to fix your problem. Like the other gentleman said, defrost is having to kick on too much. It's doing the best it can givin the conditions outside. If you don't have enough power supply for electric back up heat, then a gas furnace or propane furnace will work also, depending on your needs. Heat Pumps are a like a full time fan, they are designed to heat your home at a steady rate unlike forced gas units that turn on extremely high temps and then shut off... Ensure your charge is correct, givin your tempatures the unit sounds to be working correctly, however a second opinion is always a good piece of mind before you spend money on emergency heat.. Hope that helps..
Posted on Dec 02, 2008
meBNme
  • 334 Answers
SOURCE: heats for 15 - 20 mins then blows cool air
Look for an outdoor thermostat/temp sensor and if you find one chack to see if its adjustable. (adjustments probably found on the board.)
It could also be wired to bypass the heatpump altogether when temps are below 40.
you will want to adjust, rewire or remove that t-stat/sensor.
In some areas they are really not needed. What state are you in?
Posted on Mar 06, 2009
pierre1811
  • 144 Answers
SOURCE: unit blows cold but freezes up
You are low on refrigerant.
Posted on Mar 24, 2009
  • 8 Answers
SOURCE: fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
Posted on Mar 30, 2009
relaga58
  • 158 Answers
SOURCE: PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
Posted on May 09, 2009
I have a 2006 Suzuki Forenza. The A/C blows nicely until we drive about 20-25 minutes on the hwy. The is continues to blow but no air comes out of the vents or very little but you hear it blowing like...
not sure if you are saying
its not cold only
its not blowing hard
its not blowing hard but its cold.
its not blowing hard and is not cold.
is it a flow issue or only a temperature issue.
this is key to the diagnosis.
my guess, is its only a temperature issue, not flow.
so lets work that.
1: the AC belt is slipping at high speed.
2: the AC clutch is slipping.
or something far more complex that only tools can find.
working on cars takes hands on and tools.
guessing is near fruitless but there, i tried.
Aug 30, 2013 | Suzuki Cars & Trucks
A/C Blows warm when idle
I can't say much without having the actual code.
When the ac stops blowing cold at idle, the most common reason is not enough air flowing thru the radiator, or the radiator fan is not running and the only air flow is when the vehicle is moving.
May 09, 2013 | 2005 Chevrolet Colorado
2006 magcab ac stopped blowing out cold air olny hot air blows out of vents
check the freon charge for the a/c system to low can shut off the cutch
Jul 13, 2012 | Cars & Trucks
The ac is not blowing air
there is a resister for the blower motor near the motor under the dash behind the glove box the connectors over heat then they loose electrical contacts look at the connector for melting
Jul 12, 2012 | 2004 Cadillac CTS
My ac is cold and is basically fine. but the problem is that it doesnt blow hard. it sounds like it is but you barley feel anything. what do i need to replace so it blows hard?
For this issue, have the evaporator cooling unit cleaned. The reason why it doesn't blow hard is the dust and dirt are covering the evaporator cooling unit. The dirt and dust are also very harmful to the cooling unit. Have it cleaned and you will see the difference. Hope this helps.
Jul 11, 2011 | 1987 Nissan 300ZX
Hardly blows cold air
use a heat gun to melt the iced pipes before using it again. have your aircon's thermostat checked/replaced. the thermostat's supposed to stop the compressor at a certain temp. which is before it freezes the pipes
May 20, 2009 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
