Question about Hitachi C10FCE2 10" Compound Miter Saw
I cant find the locking pin on the hitachi c10fce2
How do i replace switch on Hitachi miter saw
Oh come on.
You know the answer.
You start taking out screws until you can see the switch and then you replace it with a new one from the parts supply store.
Then you put all the screws back in.
Oct 16, 2014 | Hitachi C10FCE2 10" Compound Miter Saw
How do you unlock it so you can lift the blade up. Not in the manual
There is a small pin or lever on the right side, a few inches in front of where the hinge is. You have to pull the pin out about a half inch. But the spring that is trying to raise the saw will be working against you. So you have to push down slightly on the front of the saw with your left hand while you pull out the pin with your right hand.
Sep 15, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
Cant pull out locking pin on miter saw
There is a heavy spring which is trying to hold up the saw that is working against you. Press down on the handle of the saw so that it moves down a little, now you should be able to pull out the pin.
Good luck.
Jun 13, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
I'm having problems replacing the blade on my Hitachi C10FC2 miter saw
it should have lock button some wear on it push it in. this will keep the blade from move. so you and take the blot off
Jan 18, 2011 | Hitachi C10FCE2 10" Compound Miter Saw
Is there an arbour lock on this saw so that I can tighten the bolt after putting on a new blade?
i cant tell you for sure, but, usually just put a piece of wood on the plate or deck, pull the saw down and have the blade make contact with the wood. tighten the nut and hold downward pressure
Dec 29, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Lost my manual. Need to know how best to switch blade
There is t shaped scocket type wrench that came wuth the saw that pushes into the saw next to the rear handle it fits the bolt that holds the blade on.There is l shaped metal locking buttom on the front of the motor houseing. The bolt has left handed thread so it loosens in the oppisite deriction as a normal bolt clockwise. push the L shaped button in to lock the blade loosen the bolt remove the washer and blade install new blade in reverise order
Dec 22, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Hitachi C10FCE2 10" Compound Miter Saw Logo
121 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
