Question about Sony SA-WM500 Subwoofer
Sub keeps cutting off - Sony SA-WM500 Subwoofer
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
Is there a crossover in the ada885 sub box do i disconnect when using external amp
usually the external amplifiers have potentiometers that you can adjust called sub sonic and LPF. Find what your sub needs to be setup to and set the LPF to that frequency, usually 40-60hz.
Find the tuning of your box or the sub sonic frequency cut-off and set it there. usually 30hz and under, this will keep your subwoofer from unloading and damaging itself.
Nov 10, 2013 | Car Audio & Video
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
When i turn the music up sub cut off blue light stay on red triangle cuts off
Hi, the amp is going into protect mode. You can either keep it turned down or possibly reconfigure the speaker connections for a higher impedance. If you tell be the model of your sub, I may be able to suggest a better arrangement.
There is a manual here if you don't have one: http://manual.kenwood.com/en_contents/attachDownload/6017/
May 08, 2011 | Kenwood KAC-7204 Car Audio Amplifier
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
My amp keeps cutting on and off, it will play for a bit then it shuts off. What could cause this? I never had this problem before and I'm running the same subs
It might not be the subs causing your amp to cut in and out.
First, I would check your ground connection. Make sure all is tight and connected properly, both ground chassis and from the amp.
Second, check your 12v remote turn on. Make sure you are receiving proper voltage.
Jan 09, 2011 | MTX (TC4001) Car Audio Amplifier
System Cuts Off
your amp is tripping out because the subs a drawing to much power get a better amp alpine subs demand a lot of power try a high current amp
Jun 30, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Lifestyle 30. sound stops, i unplug and plug back in and works for short time and quits. unpllug and plug back and works a short time and quits.
What you describe, sounds like a speaker short. Are you using the Bose wiring with their ends and no cuts in the wire? (splices) It's not too uncommon to extend or shorten a wire. The fastest way to find a short is to disconnect your speakers at the speaker. Be careful to keep the wires separate if they are not on plugs and turn on. If it cuts off (power) or says (protection) on the display that lets you know your speakers are ok and you have a short in the system or a wire. Next, disconnect wires at the sub one by one and test until it causes the system to cut off or short. Leave that speaker disconnected from the sub and test with all others connected. Now you've located the channel that has the problem. First just connect the wire again to the sub. if it cuts out, run a new wire from the sub to the spkr, for testing purposes make it a short wire if possible and test. If you need to use a Bose plug at the sub to test spkrs go buy one at Bose, don't cut your factory wire just yet. If a new plug works then cut and replace. Make sure you use electrical tape not scotch tape or duct tape. If it works fine, test the new plug on the old wire and see if it works. If it does your done, if it doesn't, run a new wire to the speaker with the new plug on it. If after all this and it still doesn't work. Sounds confusing I know, It's just process of elimination, that's how we do it in the field. If all your speakers are disconnected and it still cuts out, it could be the sub or the receiver. Take it to a Bose store and they can check each piece for functionality. If it needs repaired let Bose do it. Hope this helps.
May 10, 2009 | Bose Lifestyle 28 System
Harman Kardon Sound Sticks Sub Problem
Oh well, buy new ones. What are harmon kardon sticks anyway?
Mar 09, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Sony SA-WM500 Subwoofer Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
