Question about Apple Promise Technology Pr602us Pegasus R6 12tb Raid Encl Thunderbolt Hw Raid
Drive offline in pegasus R6
Three of my 6 drives in R6 show offline, do not believe is bad HD, just some error I'm missing.
CISCO 6248 beep sound
Beep Codes Cause (Depending on RAID Level)
3 seconds on, 1 second off
  • RAID 0: One or more drives offline.
  • RAID 1: Two drives offline.
  • RAID 5: Two or more drives offline.
  • RAID 6: More than two drives offline
1 second on, 1 second off
  • RAID 1: A mirrored drive failed.
  • RAID 5: One drive failed.
  • RAID 6: One or two drives failed.
1 second on, 3 seconds off
A hot spare drive has completed the rebuild process and has been brought into the array.
Jul 24, 2014 | Cisco UCS 6248UP 48-Port Fabric...
3 of 6 drives on Pegasus R6 (12TB) Array show offline
If this is a RAID 5 and the data is of any importance I would definitely suggest consulting an expert. RAID can be tricky. Read some precautions here :Best Way to Recover Failed RAID 5 Array Quickly and Affordably Proceed with caution, I cannot tell you how many times failed attempts have come into our office making things next to impossible to actually recover the data.
Apr 13, 2014 | Promise Pegasus R6 12TB RAID System...
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
E68 showing up on tv screen
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans. If the unit operates successfully without the hard drive, simply replace the HD. If the unit continues to show the error code with no hard drive connected, this will confirm that there are serious issue that concern the internal connection. Contact Microsoft in this case.the console will need to be repaired.
Nov 11, 2009 | Microsoft Xbox 360 Console
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
PXE-E61 Media Test Failure
when you get that error message, it's mean that your laptop isnot detecting your hdd, that's why it try to boot from network. Since you said you replaced hdd recently,
I believe your motherboard is bad.
About the fan, you can open the back door,
you just need to open the door and you can see the cpu fan.
Jul 02, 2008 | Acer Aspire 5100 Notebook
Lacie harddrives All not showing up
My guess is that your thumb drive was somehow
infected with a virus!
( The thumb drive has probably been connected to internet)
It sound like a virus infection because all the drives
has been affected !
Hope this help! Please vote
Apr 29, 2008 | LaCie d2 (300769) 200 GB Hard Drive
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Sn 3250 router problem
Ok, I'm confused... are you sure this isn't router that you're mentioning isn't a SAN Switch? A StorageTek/Brocade 3250 switch... and this is a StorageTek Scalar 100 Tape Library with Fibre aware LTO Drives. The Library Users Manual can be found at http://downloads.quantum.com/scalar/S100/omS100UsersGuide.pdf. Switch information can be found at http://www.storagetek.com/products/product_page2304.html. I'm not a Sun guy, so I would suggest that you contact them to find out which versions of firmware for the switch that they have certified. With HP, there are certain versions of firmware that they certify with HPUX... and specific versions of HBA drivers that work better with HPUX as well. If it is, in fact a Brocade 3250, I would suggest that you start with a "switchshow"... figure out which port drive 4 attaches to... do a "porterrshow #" (# represents the port found) to see the port error statistics... you want to check the loss of signal and link failure count. I would do an "sfpshow #" to see the status of the transciever as well. Let us know.
Oct 04, 2006 | Storagetek StorageNet Router 3250
Apple Promise Technology Pr602us Pegasus R6 12tb Raid Encl Thunderbolt Hw Raid Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
