Question about Arris SURFboard Gateway SBG901 DOCSIS 20 Wireless Cable Modem RoHS (55631500500)
How to reset NAT on Motorola SGB901 - Arris SURFboard Gateway SBG901 DOCSIS 20 Wireless Cable Modem RoHS (55631500500)
I am gaming and my game keeps giving a message that says ( my router's NAT Type is STRICT) but I'm hooked up directly to my motorola surboard. how can i fix this please.
Did you look up NAT on the web??? in all cases in gaming terms NAT has noting to do with routers it's a term used for filtering opponents (other users) in a game... in routers the term NAT stands for Network Adress Translation) nothing to do with gaming, fire walls or ports, only ROUTING, WELCOME TO THE NETWORK/GAMING WORLD... look in to the game settings instead of the router's
Cheers!
Jul 30, 2011 | Arris SURFboard® SB5101 Cable Modem
We have a Sunbeam Microwave Model #SGB901, purchased less than a year ago, and it stopped working yesterday. The interior light goes on, the power buttons work, but it does not heat anything. Can you...
Could be an internal Thermal fuse or cut out reset if one is at back of casing, More seriously could be the Magnatron in which case renew machine....
Feb 19, 2011 | Microwave Ovens
How do you bridge a modem ? i have a problem trying to change my nat 3 to nat 1. i have opened my router settings and reset my ps3 settings.i have been told that my problem can be fixed by bridging the...
Bridging the modem actually disables the dhcp server on your modem...
If you bridge the modem, then the dhcp will get disabled which in turn disables NAT on your modem...
If you contact your ISP they will help you to bridge the modem... because bridging varies according to the ISP...
Jan 23, 2011 | Arris High Speed DSL Modem
My SBG900 router's NAT type is set to moderate when checked on xbox live connection, I tried typing the IP adress into a web browser and can only get to the log-in page, I read that the log-in is naturally...
Try user as "admin" and passwords as "admin" or blank or "password" or "1234" then check. If still not able to access then you need to RESET it. For that press RESET button for 10 seconds reset button is in the back side of router. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 03, 2010 | Arris SURFboard SBG900 Wireless Router...
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
Motorola SBG900 NAT problem.
Nat can be turned off in the sbg900, but not recommended, as it also shuts down the dhcp, which is responsible for providing ip addresses to you PC,xbox etc.. I do not believe there is a work around. Nat sometimes limits certain games, but I have not found any games other than COD that I have ever had problems with. bottom line, if you need to disable nat, then you will need to plug directly into modem.
May 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Change nat type
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
How to change the NAT of motorola PSA15R-240
you will need to change some settings on the router.
reduce the MTU. if the MTU settings of the router is 1500 then change 1365.
also you will need to open some ports on the router.
click Here for more info
Nov 30, 2009 | Motorola Computers & Internet
How do i open nat for modem
hi you can enabel the NAT on your zoom modem or motorola router from here
http://www.portforward.com/english/routers/port_forwarding/Zoom/X5/X5index.htm
just select the modem and router and then select the application and you are good to go.
Mar 30, 2009 | Zoom X5 5654 DSL Modem (DH5654)
Open Questions:
See all Arris SURFboard Gateway SBG901 DOCSIS 20 Wireless Questions
Arris SURFboard Gateway SBG901 DOCSIS 20 Wireless Cable Modem  RoHS (55631500500) Logo
49 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
