Question about HP Laserjet P4015x Printer
I have alserjet p4015x that is not powering on. I have changed the psu but have the same problem. Please assist
  • 41 Answers
If you have done all the basic functions like change power cord,try different power sockets then most likely you need to replace the formatter.
Posted on Jun 18, 2009
My desktop was fine last night but today will only power up for 1 or 2 seconds and switches off again,any ideas please?
psu replaced with known good power supply no change
cmos either reset or pull the battery to reset it no change
checked motherboard led for power. power supply led for power.
then start unplugging things from the motherboard. any cards plugged into slots checking each time to see if it powers up. was there a storm that could fry one of them.
Aug 23, 2015 | Computers & Internet
DIY foxconn tower caseTSAA891 connection to abit NF7-S Motherboard
What are you asking for assistance with? Connecting the wires (if so which ones) or finding a manual?
What cables are you having trouble with? If it is the power supply cables you are having problems with, bear in mind that most modern motherboards/PSU's use a 20+4 pin arrangement. Some older PSU's have a different connector.
It could be that you need to update the PSU to match the requirements of the motherboard
Oct 11, 2007 | Computers & Internet
MANUAL FOR HP LASERJET P4015X
Please send me an email to LBrown18062@hotmail.com I will send it to you. please put (hp p4015) as the subject.
Oct 23, 2012 | HP LaserJet P4015x Printer CB511A - $50...
How do i print on legal paper
Usually this setting is in the computer under the letter set up where your can change size, Landscape, Color, etc look under the printer program in the computer.
Nov 07, 2017 | HP Laserjet P4015x Printer
Error 51.10 hp laserjet p4015x
Laser/Scanner error. Go the the Diagnostics Menu. Run the Laser/Scanner motor component test.Make sure that you can hear the motor rotate. If the error persists replace the Laser/Scanner assembly
Sep 07, 2010 | HP Laserjet P4015x Printer
Computer won't boot - there's a flashing 1 and 3
Either the power supply has failed or the power cable is not getting power to the board (if the lights are amber). Check that the power cable from the power supply to the motherboard is fully seated. You may need to replace the power supply - you will need one that will fit your case and matches the various devices and plugs that you currently have. (20+4 pin for the motherboard gives the most flexibility, additional power for the CPU (4 pin or 8 pin), SATA if you have SATA devices, regular 4 pin peripherals for IDE hard drives and optical drives, 4 pin floppy, video card (if you have a PCIe card that needs a 6 pin plug), etc.)
I hope this helps.
Jul 13, 2010 | Dell Precision Workstation 490 - MT -...
D945GCCR Motherboard: after a thunderstorm the psu got damaged so I repl...
Sorry, the motherboard has been fried - nothing you can do, it's dead. Replace it.
May 18, 2010 | Intel D945GCCR Motherboard
Hang & Restrarting of PC
Change the power supply, i.e. the SMPS with a new one of the same rating and make sure all the power & data cables are snug tight in their respective slots. Also take out the RAM, clean it and replace. Try to remove any dust if possible from all the sockets/connectors...........sodeep
Apr 30, 2009 | ASUS Terminator P4 PC Desktop
[Emachine C2684] Systems appears to be getting power, but won't boot.
Track down the motherboard manual, the motherboards of branded machines are usually made for them by PCChips or Foxconn or someone similar.
In the manual identify wich connectors on the motherbaord is the front power switch. Disconnect the front power switch and plug it all abck in again to see what happens with the power switch disconnected.
If you feel brave enough you can momentarily short the motherboard powerswitch connectors and the machine will start.
the front power switch is a momentary switch so only short the motherboard pins long enough for the machine to start.
Jul 30, 2008 | E-Machines eMachines Desktop PC
Graphics card power
I suggest you change your PSU if you want to play hi end games and do more graphic stuff. This PSU will work only if you use your computer for low graphic things like busines software Office and internet, if you use CAD you better change it or it will cost you more money.
It would be more helpful to tell us what computer do you have, and what card did you install.
Jan 31, 2008 | Computers & Internet
HP Laserjet P4015x Printer Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
